Sky HD - supplied HDMI cable
14 replies [Last post]
andyh
andyh's picture
I have just upgraded to Sky HD, I am currently using the HDMI cable supplied by Sky. Is there any value in buying a better cable? I have noticed that the SD channels seem a little softer compared to my old sky box, although I did have that connected with a QED performance scart cable.
The HD picture, especially on the movie channels looks fantastic though, which is good!!
Any thoughts would be useful, thanks.
maxflinn_banned
maxflinn_banned's picture
Re: Sky HD - supplied HDMI cable
no ..
the sky hd boxes are not great at upscaling , go into the menu on it , and set the output to 576i , so your tv will be upscaling , this may improve things , the hdmi cable has nothing to do with the picture , if the cable works , its fine...
__________________
laptop...airport...marantz pm7001...dynaudio dm 2/7's...
professorhat
professorhat's picture
maxflinn:
Would be a pretty poor picture without it Stick out tongue
True Blue
True Blue's picture
yes..
Quality cables and shielding make a difference.
__________________
Sources: Rega P7+Exact through Stagleine n
Rega Saturn / Sonos - > Rega Dac -> Chord Signature
Pre: NAC 202 / Hicap / NAPSC
Power: NAP 200
Speakers: PMCGB1i wired with NACA5
The_Lhc
The_Lhc's picture
maxflinn:
NO! If you set it to 576i then the box will DOWNscale HD pictures, which complete defeats the object of getting SkyHD, set it to Auto, then the TV can upscale SD pictures and receives HD pictures at 1080i.
__________________
No signature worth mentioning...
maxflinn_banned
oh, i didnt realise there was an auto on it , dont have sky meself Yes
__________________
daveh75
daveh75's picture
the_lhc:
maxflinn:
SkyHD boxes dont output 576i via HDMI either! They all deinterlace the native 576i signal.
__________________
JVC DLA-X30•Grandview Cyber Series (92")•LG 50PX990•Oppo BDP-93•Humax Foxsat HDR•Humax HDR-Fox T2•Vu+ Solo²•WD TV Live•Onkyo TX-NR818•Mackie HR824 MK2•BK Monoliith DF
Sonos Connect•Studiospares Seiwin 5A
Brian123
Brian123's picture
daveh75:
the_lhc:
maxflinn:
I set my SkyHD box to 1080i and let my TV do the deinterlacing - it does a far better job!
Back to the original question, I did upgrade my HDMI cable, and although the picture was better, I found a more noticeable improvement by replacing the mains cable. Yes
daveh75
daveh75's picture
Brian123:
daveh75:
the_lhc:
maxflinn:
Yes,but that still means the Sky box is upscaling SD, which they're also rubbish at.
__________________
Brian123
Brian123's picture
daveh75:
Brian123:
Agreed - it's a compromise between deinterlacing and upscaling.
Still, on my TV at least (TH-42PX80) Sky's SD content seems better in 1080i than 576p!
TheYellowPeril
TheYellowPeril's picture
Agree with that, just tried mine and although the SD pictures are not fantastic, they're better in 1080i than when set to Auto.
What did you change the mains cable to?  Better quality one or just a different standard cable?
Brian123
Brian123's picture
TheYellowPeril:
I'm using one of these mains cables:
http://markgrantcables.co.uk/shop/index.php?main_page=product_info&cPath=45_18&products_id=47
Wovian
Wovian's picture
Brian
Did you replace the mains cable on the Sky HD box or the TV to achieve the better picture?
Cookie Monster
Cookie Monster's picture
Hi Andyh,
I tried (and own) several different leads with my SkyHD box and there were very clear differences between all.
Currently use Chord Active that i got through What Hifi subscription. However you should see a big improvement in edge definition and stability with a That Cable (www.Thatcable.com) purchased a 1m one for £4.79. Won't cost the earth and you can judge for yourself.
Even though i 'could' use my Chord Active (£100+) with my Panny Blu-Ray player i prefer the rigid edged picture from the 'Thatcable' (£4.79).
I use a 42 inch tv and 77 inch projector screen and believe me there is a difference in quality on larger screens, but you don't need to spend a fortune. Heard WhatHifi use a 60 inch Pioneer so when they say they can see a difference.......
Don't get me onto Mains Leads, they make a great difference too. Love it!
Good Luck,
Cookie Monster
__________________
Philips 42PFL7404,Epson EH-TW5900 PJ, 77" Euroscreen, Yamaha YSP-2200, SKY HD, Sony BDP-S370, PS3, Tacima Mains Conditioner, Wireworld, QED, Thatcable HDMI's. Handmade Mains Cable, Sharkoon DD5.1 Headphones - Staffordshire
maxflinn_banned
hi andyh
i tried (and own) several different leads with my humax foxsat hd box , and there was absolutely no difference between them ...
__________________
