SKY HD Contrast setting???
10 replies [Last post]
PINK MOON
PINK MOON's picture
When i first got Sky HD I could access a contrast setting through the services button, now i can't find it?  I think its the normal amstard box ive got,, and im positive it has been removed? I just cant find it,, its like when you loose your wallet and you check your pockets   every 5 mins and you know it should be there,, but it just isnt, no matter how many times you look!!
The box may have been updated because i recently had to re-tune ITV HD as its not available in Scotland.
 Does anyone have any ideas?  can someone point me in the right direction?
cheers!!
daveh75
daveh75's picture
Re: SKY HD Contrast setting???
Sky removed it as an option with one of the recent s/w updates!
__________________
PINK MOON
PINK MOON's picture
Any idea why they did this? or what its currently set at, im presuming medium?
daveh75
daveh75's picture
It's set to medium afaik.
As to why they removed it, Sky being Sky don't give reasons...Though i suspect it was down to the 'high contrast bug' some boxes suffered from - probably easier for them to remove the function, rather than actually fix the bug in the s/w.
__________________
daveh75
daveh75's picture
As to why they removed it, Sky rarely give reasons...Though i suspect it was down to the 'high contrast bug' some boxes suffered from - probably easier for them to remove the function, rather than actually fix the bug in the s/w.
__________________
stu31
stu31's picture
Is it just the amstrad boxes then as mines a samsung and i still have it as an option my system version 1.32B12
__________________
LG 50PK990, Sony S370, Yamaha RX-V2065, Sky+ HD, AE Aegis EVO 3B 5.2, Belkin PF40, Wii (softmod) + 2TB WD, B-Tech Ultragrips, Harmony 555, Netgear XEB1004 Homeplugs, Custom AV Rack
daveh75
daveh75's picture
No not just amstrad boxes...They were doing the updates in batches so you may not of had it yet.
__________________
chudleighpaul
chudleighpaul's picture
I can still adjust the contrast on mine.Smile
stu31
stu31's picture
daveh75:
Ok thanks for that.
__________________
tvmog
tvmog's picture
daveh75:
What was the "high contrast bug"? I currently run my contrast setting at high, as I think that it gives a better picture with my TV. I shall be very miffed off if Sky decide to reduce my picture quality rather then spend some of their millions of pounds profit on finding a proper solution to yet another box reliability issue.
daveh75
daveh75's picture
The 'high contrast bug' meant that on some HD boxes the contrast was stuck on high setting. You could go into the menu and adjust it but it didn't actually change the output.
__________________
