Sky +HD compatable with hdmi???
49 replies [Last post]
sdrew1980
sdrew1980's picture
hi, pretty new to all this stuff but really enjoying it. Just ordered sky +HD to work along side a 1080 plasma, blueray and home cinema system. On my present system, everything runs through amp (onkyo sr50cool then a single lead to tv. will this be the case with sky (just a hdmi into the amp)? - i've heard that you need a optical something or other to get 5.1
 also parents have same setup but with a soundbar through a sub/amp. what do they need
 help!!!
daveh75
daveh75's picture
Online
Re: Sky +HD compatable with hdmi???
Sky+HD boxes can only output stereo over HDMI, so yes you'll need an optical/coaxial cable for DD 5.1 sound
__________________
jonbates
jonbates's picture
hi  dave
Just read this and now im suitably confussed, i have sky hd and have it connected to to my denon avr 2310 surround sound reciever, via a wireworld chroma 6 hdmi lead to the sat / cbl input on the reciever, are you saying that this does not give the best sound performance and it would be better to use an optical lead to connect the two to give dolby digital? the other problem i have is that the denon amp only seems to have an optical input for tv or dvr,  so do i have to connect it via audio cables and the hdmi?
 Cheers in advance
simonlewis
simonlewis's picture
jonbates:
hi  dave
 Cheers in advance
Connect you sky HD to your tv with HDMI & connect a optical lead from your sky HD to the dvr input on your amp for sound.
__________________
formerly known as slewis ---
simon's system
jonbates
jonbates's picture
Hi Simon
thanks for that, sorry to be pleb but are you saying use the HDM I 2 input on my sony tv while leaving the hdmi 1 input from the amp to the tv in place and then use the optical lead to connect the sky hd box to the dvr input on the amp? if so what source do i need to select to watch the tv?
simonlewis
jonbates:
Hi Simon
Yes one HDMI from your amp to your tv & HDMI from your sky box to your tv, so your tv has two HDMI connections.
__________________
simon's system
jonbates
jonbates's picture
done that and i only get sound but no picture when i select the dvr stereo input on the amp! do i have to change the hdmi imput to HDMII 2 on the Tv?
jonbates
jonbates's picture
Already have the answer, have switched the tv to hdmi 2 and now working, do you think this is the best sound that can be achieved or are there now further tweaks that can be made?
jonbates
jonbates's picture
have just unplugged the hdmi lead from the hdmi input 1 on the tv and tv output on the amp and it has made no difference to the sound or picture!
jonbates
jonbates's picture
Hi Dave
Can you give me any advise on this? is is what i have done the best possible connection for both sound and picture quality?
Andrew Everard
Andrew Everard's picture
Yes: HDMI straight to TV, digital audio to receiver. The only reason for the HDMI from receiver to TV is if you have other sources being connected into the receiver via HDMI, such as a Blu-ray player, for example.
Oh, and you should have the Sky box digital audio output set to Dolby Digital, and then you should get surround sound through the receiver when surround is being broadcast.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
jonbates
jonbates's picture
Andrew
many thanks for coming in, all this is very confussing as im sure your aware from the editorials in your magazine, reading other threads people have said that using the av reciever is a better option for the picture as the upscaling is better from the amp rather than the cheap componants that the sky boxes use, i may be missing the whole trick here and appologise if im sounding like a numpty, your advise would be to use the hdmi from the sky box straight to the tv and themn use the optical output from the sky box to connect to the dvr on the amp, and as ive found out i dont need to use the amp to tv connection as a result, im presuming this gives me the optical 1080 picture quality?  there is a problem though! i do have a sony blu ray dvd connected to the amp via hdmi, you suggested in your last reply that this may cause a problem, can you please elabourate,
Ps i also note the Sky box digital audio output needs to be set to Dolby Digital,, Cheers
Andrew Everard
No, I didn't say it would create a problem: you can connect both the Sky HD HDMI and the Blu-ray player HDMI to the receiver, and then the receiver HDMI out to the TV. You then use the receiver to switch between the inputs, not the TV.
But you need to make sure the receiver is configured to take the audio from the digital audio input, and the picture from the HDMI, when suing Sky HD.
__________________
jonbates
jonbates's picture
Doh,
Just read yopur reply again, are you saying that the hdmi connection from the amp to the tv needs to stay in in order to use the blue ray player?
and as an expert can you give me advise on the best sound modes to use for watchin tv, moves and music, i know it may depend on how its broadcast but are there top two modes for each?
Many thanks
Andrew Everard
Yes, you need the link from receiver to TV in order to use the Blu-ray player.
And I'd use direct mode for all sources for the best possible results, so the Sky HD runs in Dolby Digital when available, and defaults to stereo for other broadcasts, and Blu-ray is played in whatever format is coming off the disc.
__________________
sonycentre
sonycentre's picture
Yes you have to connect your blu ray player to your amp with 1 hdmi cable then use another hdmi cable to connect your amp to your tv.Then use another hdmi cable from your sky+hd box to your tv,then use an optical or coax cable(phono to phono lead) to your amp.You will then have to select the hdmi imput on your tv to watch sky then on your amp select the input for sound from your sky box.As andrew mentioned make sure you set it to dolby d under the digital audio output,and make sure you also select stereo as your audio output on your sky box.....phew.lol
__________________
Founder of Tech-Smart since 15-1-13
