'Movement ghosting' with Amstrad HD box
5 replies [Last post]
terryhickmott
terryhickmott's picture
Following Sky's installation of a brand new Amstrad HD box to replace the faulty Thomson one, I'm getting 'ghosting' on side to side screen movement on all channels. I've seen this effect on Freeview, but never on Sky. The faster the movement the more a ghosting builds up either side of the actual image.
The TV's a 1080 40" Samsung 2 years old, and as far as I know it is set up correctly.
 Hope I've described the problem sufficiently
grdunn123
grdunn123's picture
Re: 'Movement ghosting' with Amstrad HD box
Check your signal stength on the Sky Box. Might be a dodgy connection in to the box
__________________
Samsung UE55F6510 LED TV, Pioneer SC-LX82, Panasonic DMP-BDT310, Monitor Audio RS5 fronts, GSLCR centre. RXFX rears, Sky HD 1TB, Chord + QED cabling throughout,Xbox 360,Iomega NAS,Apple Ipad 3,Samsung Galaxy S4, Ipod Touch 4th Gen, Samsung Galaxy Tab 2.
terryhickmott
grdunn123:
Both inputs look to be at 2/3, and as far as I can tell the cables are very secure.
grdunn123
grdunn123's picture
I would also check the cable from Sky Box to tv and replace if you have a spare, see if the ghosting is still there?
__________________
terryhickmott
Don't have a spare but the lead that's in is OK (Chord HDMI 1.3)
terryhickmott
Nice man in Comet suggested the Amstrad might have a bigger bitrate output necessitating a 1.4 HDMI lead. I declined his offer of a Monster lead for £80 Big Smile
