I have Sky HD , can someone explain to me what i need to do to get ITV HD ?
8 replies [Last post]
jasonsony735
jasonsony735's picture
I know ITV HD isnt on the Sky HD Box , What would i need to buy so i can get this channel ? Also how would i go about connecting it all up ?
Would i have to connect the Sky Dish Box 2 Cables over to the Freesat ?
Clare Newsome
Clare Newsome's picture
Re: I have Sky HD , can someone explain to me what i need to do
ITV HD is Freesat-exclusive for the foreseeable future, so you'll need a Freesat HD box as well as your Sky box.
When you want to watch ITV HD, you'll need to connect up the Freesat HD box to one of the satellite feeds that comes into your Sky HD box.
This will leave you with only one tuner of your Sky HD box getting a feed, so beware of losing any dual recordings you had planned on that at the same time you're using the Freesat box.
When you're finished watching ITV HD, simply reconnect the satellite feed into the back of your Sky HD box. You may need to reset the box (unplug at mains, wait for a couple of minutes then reconnect) as it can get a bit huffy about losing one of its signals.
__________________
Group PR Manager - Computers Unlimited;
Former Group Editor of What Hi-Fi? Sound and Vision and Whathifi.com
Twitter: @ClareNewsome
daveh75
daveh75's picture
likely that when sky fitted your hd they also fitted a quad lnb to your dish, so you should have two spare ports available  on the lnb, so you could run a third feed to a freesat box, and save all the hassle of  swapping cables over every time you wanted to watch itv hd
__________________
John Duncan
John Duncan's picture
And once you've done all that, you can sit back and watch........er........hang on there might be something on next week........er........
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
jasonsony735
Great reply Clare, That's the answer i was after, perfect , im of to buy a Freesat ... as i want to watch some of the Champions League games in HD Smile
bigblue235
bigblue235's picture
As daveh says, you'll likely have a quad lnb, so why not run another feed from that? It's pretty straightforward, you can get the cables from B&Q and the likes.
Sky+ with one input is a royal pain. I thought it'd be fine, but it's pretty annoying. Just had a week of it (due to moving house) and that was enough. Even with trying to leave the box on the correct channel for the recording, we still lost about half our recordings for various reasons.
If one show finishes at 10, and the other starts at 10, you're knacked. You have to manually end one just before the other starts, and so on. And if you're sitting in front of the TV to do that there's no real point in having a recorder Smile
If you don't fancy running a cable yourself your local independent satellite chappy might be relatively cheap?
Juzzie Wuzzie
Juzzie Wuzzie's picture
What about splitting the feed off of the single line into all three? I.e. just before the boxes that you are plugging into? Saves running extra cable - just use a "Y splitter".
__________________
Living Room: Samsung 40C7000; Oppo BDP-103EU; Onkyo SR308; Apple TV3; Airport Express; Sky HD+; Jamo A102 HSC5; Naim Nait 5i-2; Neat Iotas; Chord / Wireworld / QED / TCI interconnects and speaker wire; Harmony 550 universal remote; Tacima mains conditioner Portable: Shuffle (1G); iPad (1G); iPad Minil FiiO E1; AKG450; Grado SR60i; Sennheiser CX300II; custom Ultimate Ears Car: iPod Classic 120GB
daveh75
daveh75's picture
you cant split a satellite feed like you can an aerial, hence the need/use of multi-port lnb's
__________________
D.J.KRIME
D.J.KRIME's picture
jasonsony735:
Don't get your hopes up too much mate as not all games are in HD only usually the home games as I am yet to see any CL away games in HD even on Sky sports. Get to watch the home games in mega-real-o-vision as I am a season ticket holder at Chelsea. Hope JT dont slip up this year lolStick out tongue
__________________
My usefull posts Laughing How To Calibrate Your TV
