Connecting SkyHD box to two tvs
23 replies [Last post]
mattjax05
mattjax05's picture
Online
Currently I have my HD box connected to my main tv via HDMI.
I would like another tv in the kitchen and I hae two options at the monent:
1) Running an RF cable from the living room (this is where the aerial point is) to the kitchen and using the tvs built in digital tuner or,
2) Running some sort of connection (maybe RF again) from the SkyHD box to the kitchen.
Are these my best/only connections or, could I get a HDMI splitter and run a HDMI cable or even run x5 (component/audio) cables?
Matt
daveh75
daveh75's picture
Online
Re: Connecting SkyHD box to two tvs
If you can i'd try an run a hdmi to the second set if distance and hiding the cable aren't going to be a problem that way you'll get video and sound on 1 cable as opposed to running a  seperate component + audio cable.
But if it was me think i would probably also run a coaxial from the rf2 out on the sky box too, for two reasons.... one with the addition of a magic eye you'll be able to control the sky box from the second room and two if your aerial is looped through your sky box the cable will carry the digital terestrial signal also allowing you to utilise the tv's inbuilt tuner!
Also if hiding cables is going to be a problem you could consider using a HDMI over cat 5/6 extender such as this as hiding a pair of cat 5 cables will be far easier than an hdmi cable
__________________
mattjax05
mattjax05's picture
Online
Hi Dave
Thanks for the options, I am trying to get my head around this though!
If I ran a HDMI cable and an RF cable could I still change the channels in the kitchen when the picture is sent through the HDMI?
Not sure if my aerial is looped through the sky box. Basically my sky box consists of the two cables from the dish and one HDMI cable to the main tv!
I understand how the Magic Eye installs but how does this actuall work i.e how does the sensor talk to the sky box?
Matt
daveh75
daveh75's picture
Online
Yes you'll still be able to change channels even though your sending video+audio via hdmi
Basically the magic eye connects to the rf cable and is powered by the skybox, so yes it talks to the sky box.One thing to remember, when you set a magic eye up you need to make sure you connect the coax to the rf out 2 then go into the settings and switch the power on for rf2.
__________________
mattjax05
mattjax05's picture
Online
I see, the rf2 connection works both ways then, transmits out a picture signal and also sends in 'magic eye' data to the sky box.
Will my rf connection carry a digital tv signal?
Matt
daveh75
daveh75's picture
Online
That's right yes rf2 sends out picture and audio+receives data from the eye.
Depends what you mean by a digital tv signal from the rf out. It only outputs an anologue rf signal from the sky box itself so only sd sky, But as i mentioned before if you loop your terestrial aerial through the sky box it will allow a digital terestrial signal to pass through and allow you to utilise the internal tuner on your second set
__________________
mattjax05
mattjax05's picture
Online
Not sure if I have a digital terestrial aerial, my signals have always come from the dish. If I don't the only reason to have the rf cable would be for the magic eye and I could get all channels inc. HD content via the hdmi. Would there be any loss in picture quality splitting the hdmi into two? The longest hdmi cable would be approx 5m. Can you recommend a splitter please.
daveh75
daveh75's picture
Online
If you dont have an aerial then yes the only reason for the rf cable would be for the magic eye! If you didn't want to go the hassle of running an rf just for a magic eye you could always try an ir remote extender like this but havn't tried one so dont know how well they work!
You shouldn't have any picture quality issues as long as you use good quality hdmi cables and a decent splitter and yes you'll get all the channels on both set's including HD. One thing to remember is though, you'll only be able to watch the same channel on both sets at the same time, not independant channels!
__________________
Eh howie
Eh howie's picture
I'm In the same boat! Does your sky box have component outs?
mattjax05
mattjax05's picture
Online
Eh howie:
Yes it does.
mattjax05
mattjax05's picture
Online
Eh howie:
Yes it does.
mattjax05
mattjax05's picture
Online
Eh howie:
Yes it does.
mattjax05
mattjax05's picture
Online
Eh howie:
Yes it does.
mattjax05
mattjax05's picture
Online
Eh howie:
Yes it does.
m1rfy
m1rfy's picture
Or just get another sky box installed, Only £10 a month for the extra box. By the time you have bought a decent 5m hdmi cable you will be on you way to 6 - 8 months of the extra box paid for, plus you can watch different channels than in the other room.
daveh75
daveh75's picture
Online
m1rfy:
Plus the cost of the box/installation
__________________
