codes for itv 1hd
1 reply [Last post]
mgillespie05
mgillespie05's picture
hi guys just had my hd box replaced ,so i need to redo my itvhd .and why is it  that when they change your box they cant copy your content
daveh75
daveh75's picture
Online
Re: codes for itv 1hd
mgillespie05:
I assume you're not in England/Wales so can't access it on the EPG?
There's two FTA versions you can add, as follows...
ITV1 HD London
Frequency: 10.832 GHz
Polarization: Horizontal
Symbol Rate: 22.0
FEC: 5/6
Note- only 1440 x 1080.
 ITV1 HD Granada
Freqeuncy: 10.936 GHz
Polarization: Vertical
Symbol Rate: 22.0
FEC: 5/6
1920 x 1080i resolution
There is no facility to copy data from one box to another.
The only way it's possible, is to remove both HDDs and connecting them to a PC,then using third party software called copy+ to copy the data from the old drive to the new.
__________________
