can i connect a humax hd to...
15 replies [Last post]
maxflinn_banned
maxflinn_banned's picture
to a 26in 720p tv with no hdmi inputs, using component? i can use scart, but want the hd channels too.. ta..
__________________
laptop...airport...marantz pm7001...dynaudio dm 2/7's...
daveh75
daveh75's picture
Re: can i connect a humax hd to...
Yep...
__________________
maxflinn_banned
cheers daveh, theres one yellow and one green component video output, my component cables are red and blue, which goes to which? ta...
__________________
daveh75
daveh75's picture
It's the top 3 outputs on the Humax you want, marked Y Pb Pr. The bottom 3 are composite video(yellow) and L and R audio(red and white)
__________________
maxflinn_banned
top man daveh, thanks..Yes
__________________
maxflinn_banned
my component cables are dual point, one red one white, i presume i need a triple point one ?
__________________
daveh75
daveh75's picture
Yeah you need 3 cables...
__________________
maxflinn_banned
ah, no bother daveh, ill just use scart for a couple of days so Yes
__________________
daveh75
daveh75's picture
If you've got more than one pair of spare I/Cs just use 1 1/2 pairs, if that makes sense.
__________________
maxflinn_banned
ah, yep thats a plan..
i guess its not possible to connect to my sony blu-ray player with component? id love to see what avatar looks like on this little tv Stick out tongue
__________________
Gerrardasnails
Gerrardasnails's picture
maxflinn:
Yes you can. Remember, you will also need audio cables as component is video only. Also, don't get mixed up with composite cables - component is red, green and blue. You can get some brilliant cables on eBay for under £20 as hdmi has taken over.
__________________
Screen - Samsung UE46D8000.  Sources - Dell Zino HD 410; Sky HD; Sony BDP S550; Wyred 4 Sound DAC1.  Amps - Yamaha RX-A3010; SimAudio Moon I-3 RS.  Speakers - Vienna Acoustics Mozart Grand; Vienna Acoustics Waltz Grand centre; Proficient Audio W690 rears; Monitor Audio RSW12.  Cables - Van Damme Blue 4mm speaker cable; Townsend DCT300 and Atlas Voyager interconnects; Van den Hul Optocoupler.
John Hereford
John Hereford's picture
On a similar theme, does anyone Know whether you can scart a Humax HD Freesat receiver to an old CRT TV and be able to use the SD iPlayer function (or can this only be achieved through an HDMI connection)? I have emailed Humax with this question, but did not get any response.
I would be grateful for any help
maxflinn_banned
Gerrardasnails:
maxflinn:
i have three sets of cables, dual point, red and white, will they suffice gerrard? ta..
__________________
daveh75
daveh75's picture
maxflinn:
Gerrardasnails:
maxflinn:
Strictly speaking they're audio I/Cs, but they'll carry component video no problem as will composite cables...Don't waste your money on 'component' cables max, especially as it's a short term solution.
__________________
maxflinn_banned
ill give it a shot daveh, cheers guys..
__________________
maxflinn_banned
will the hdcp prevent blu-rays from playing over composite output?
a friend who lent me the tv reckons it wont work...
__________________
