bush freesat box
7 replies [Last post]
pauldownton1979
pauldownton1979's picture
i have the buget hd bush freesat box sorry model number slips my mind - its about £100 at argos
my problem is that altough i have 97% signal i cannot and never have got c4! does anyone have or have knowledge of this surfacing before? i can get c4 + 1 more 4 e4 i have tried retuning etc PLEASE HELP!!!!
simonlewis
simonlewis's picture
Online
Re: bush freesat box
I had a similer problem yesterday/today i re-tuned my tv & i couldn't get itv or channel 4, i have two aerials in my flat, one when the property was built & one which was installed ten months ago, i tried the newer aerial & i got the channels back.
so quite possibly it could be your roof aerial.
__________________
formerly known as slewis ---
simon's system
pauldownton1979
even with 97% signal ? surely that cant be the case can it ?
Pete Shields
Pete Shields's picture
are you connecting your freesat box to a tv aerial instead of a sat dish?Smile
simonlewis
Online
Im no expert, if daveh75 comes along he will give a better answer.
OOPS sorry my mistake, i thought you said freeview.
__________________
simon's system
pauldownton1979
i live in a block of flats. its conected to a communal dish. i get good quality pic on both hd and sd on every channel except channel 104 (c4) where i get no picture. every time i switch to 104 it just says new service please wait. im 100% its not a signal/aerial/dish problem. i think its a fault with the box
daveh75
daveh75's picture
It certainly doesn't sound like a dish/lnb problem as you would expect it to effect a whole mux of channels,though it may be worth checking with neighbours to see if any of them are having issues with ch4 just to be sure.
It could be be that the box is faulty/tuner isn't very sensitive to weak signals,and channel 4 is one of the weakest signals.
There is also another possiblity and this may sound strange,but do you have a DECT cordless phone in close proximity of the bush STB  as there is a known issue with DECT phones causing interference with satellite signals and particularly with C4 and on occasion E4, so if you do have one try unplugging the base unit and see if channel 4 comes back.
__________________
JVC DLA-X30•Grandview Cyber Series (92")•LG 50PX990•Oppo BDP-93•Humax Foxsat HDR•Humax HDR-Fox T2•Vu+ Solo²•WD TV Live•Onkyo TX-NR818•Mackie HR824 MK2•BK Monoliith DF
Sonos Connect•Studiospares Seiwin 5A
DenP
DenP's picture
A long shot but try checking the post code you've entered.
Where I live Channel 4 is on 120, and S4C, a Welsh channel, is on 104, so that may possibly be your problem.
