Bt Vision
Does anyone no if you can make your BT vision multi room ? I have two bt vision boxes but when they are both plugged in to the powerline adaptors you cannot record on them unless you unplugged one of them does anyone no any way to resolve this or can you only have one plugged in ?
From BT Vision Support on their forum (March 3rd 09)
"Multiple VBoxes are still officially on the 'don't try this at home' list, but good luck in getting them up and running. We are considering a multiroom option but haven't quite decided how to implement it at the moment. A significant challenge to full support is getting more than one QoS stream running on the same line - esp. for lines operating at rates below that needed to run dual streams."
- Login to post comments
As far as I know you are only allowed one recording device per account, if you try and hook up two STBs the Vision system won't let you do much at all :-( If you boot up the STBs separately are you able to record on both or will only one work as a PVR?
Adrian
