BBC One HD launches 3 November!
"BBC Services on Digital Satellite are moving on Monday 18 October 2010
Listed below are the frequencies for BBC TV channels and radio stations available via satellite. The BBC is rationalising its service line-up on digital satellite, and from the early morning of Monday 18 October 2010, the service line-up will be as set-out in the chart below. Because of software limitations, BBC Red Button interactive channels are currently only available with Freesat or a Sky set-top box and viewing card.
Other free channels are also available, but some - such as Channel 4 and Five - are encrypted and require Freesat or a Sky set-top box and viewing card.
Viewers with a Freesat set-top box will not need to do anything, as the Freesat EPG (Electronic Programme Guide) will be updated to reflect these changes. If you experience a problem, it may be resolved by switching your Freesat box off, and then on again. If you see an on-screen message advising you to retune, please follow the instructions on-screen.
Viewers with a Free-to-Air receiver will need to retune to continue to receive the BBC services that are moving."
http://www.bbc.co.uk/reception/info/sat_frequencies.shtml
Scroll down to, 'Changes to the previous line-up of services on BBC DSAT4' and you'll see one of the changes is 'BBC One HD from Wednesday 3 November'
YVW...
And watch this space, because if the BBC follow the usual convention, they'll probably start test broadcasts within the next few days (it's usual for broadcasters to begin tests 2 weeks before launch) in which case i'll post the details for a sneak preview...
Will do and thanks again.
daveh75:YVW...
Maybe that explains why BBC1 has gone on the blink since yesterday here in Ireland...I have two settings for the same channel appearing on the EPG but neither is working due to a 'technical difficulty' ...strange ?!
ricardo65:
daveh75:
YVW...
Yep they shifted channels about on various transponders to make room for BBC 1 HD.
Have you tried doing a channel scan on your box? Though Sky/Freesat boxes should of updated automatically...
BBC1 HD now officially confirmed to be launching 3 november by the BBC Press Office...
http://www.bbc.co.uk/pressoffice/pressreleases/stories/2010/10_october/21/bbconehd.shtml
So it's taking over BBCHD's channel number on Sky then (143)? Wonder where that'll end up?
the_lhc:So it's taking over BBCHD's channel number on Sky then (143)? Wonder where that'll end up?
"BBC HD will be available - from 3 November - on Freesat channel 109, Freeview channel 54, Sky channel 169 and Virgin Media channel 187"
As per title, BBC One HD has now commenced testing, so if you wan't a sneak peek it can be added via the 'add channels' menu on Sky HD boxes or viewed in 'non - Freesat' mode on Freesat STBs/TVs using the following settings.....
Currently labelled as '6941' and carrying test footage and now/next EPG data for BBC1.
Frequency: 10.847 GHz
Polarity: Vertical
Symbol Rate: 22000 (22.
FEC: 5/6
nice one daveh75 do you know if the stuff they are showing now is a simulcaqst of bbc 1 or just random stuff, cant wait to see kat slater in hd.![]()
It's just random test loop footage atm...So far i've seen clips from first/last night of the proms,tennis,shooting stars,who do you think you are and a nature doc.
daveh75:As per title, BBC One HD has now commenced testing, so if you wan't a sneak peek it can be added via the 'add channels' menu on Sky HD boxes or viewed in 'non - Freesat' mode on Freesat STBs/TVs using the following settings.....
Polarity: Vertical
FEC: 5/6
Hi got it using the add channels menu as there's nothing on my actual tv guide, channel 169 doessn't exist is it just to early to get it appearing on the guide yet ?
It's still to early. It probably won't appear on the EPG till mid-morning on the 3rd...
Will it be regional? BBC Scotland etc? Or will BBC Scotland block it along a similar vein as STV have with ITVHD?
Cheers,
Cofnchtr.
Cofnchtr:Hi,
Danielle Nagler's blog says that:
"We also won't be able to bring you regional news programmes or, if you are in Scotland, Wales or Northern Ireland, your own versions of BBC One in HD, and the programmes shown on them.
"I'm sorry, this is something that we are working on, but the requirements of HD channels mean that we have to start with just a single version. Of course, you'll still be able to see your national and regional programming on your standard definition BBC One channel."
- Login to post comments
Nice spot, thanks for the info Daveh75.
