BBC HD and BBC 1 HD No picture
When i go to BBC HD channel i get the sound but no picture, all the other HD channels are fine but not the beeb ones.
Anybody know why this could be?
Are you using Sky, Freeview or Freesat?
Have you tried powering down/rebooting the box?
Yes i have, it's done this before and a reboot had sorted it but has'nt this time round , was'nt sure if it was a problem on the beebs part or not.
Any ideas?
They're both working fine on my boxes so isn't a broadcast issue. Try a planner rebuild if you haven't already.
To do a planner rebuild,
On the remote, press "Services" followed by 0-0-1 in quick succession (which get's you into the installer menu)
Then scroll down to "Planner rebuild" and press enter or press 7 then enter. (Don't worry a planner rebuild won't delete recordings)
Yep, wait till your recordings finished.
