BBC channels have disappeared on humax pvr after digital switchover retune - Help!
10 replies [Last post]
Fraz1
Fraz1's picture
I have retuned my tv and humax pvr today as advised to do as part of the digital switchover process.
After retune my tv is fine with all channels receiving a good signal strength. My humax freeview pvr has lost all BBC channels though so I cant watch them or record them through the pvr.All other channels are available and watchable through the humax. It is only BBC channels that have disappeared
I have tried several retunes on the humax, both manual and auto, but to no avail.
Has anyone else experienced this problem and does anyone have any idea what might be causing it or how to address it?
The humax is a freeview non hd pvr.
Any help would be much appreciated.
__________________
Nad C542 cd, Nad C352 amp,Epos M5 speakers on Custom design stands,Chord company chorus interconnect,DNM precision speaker cable.
chudleighpaul
chudleighpaul's picture
RE: Freesat, Sky and Virgin
You could try re-booting it before retuning.
chebby
chebby's picture
The usual routine is to power off, remove aerial lead, power up and do a full scan (without aerial plugged in) then power off, leave powered off for a few minutes and re-attach aerial lead, power-up and re-scan.
(By 'power off' I mean remove power by switching off at the mains, not standby.)
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
bob.g
bob.g's picture
I'm having a similar problem with BBC Freeview = "No signal received". I've not been able to receive any BBC Freeview for last few weeks, although all other channels are OK.
Diamond Joe
Diamond Joe's picture
Most bizarre. Try going into the installation menu, select default setting (I'm assuming all Humaxes are pretty much the same) press yes, once it's reset itself do an automatic search. That might fix it.
__________________
He's not a diamond geezer, or called Joe!
grifz
grifz's picture
No ...BBC.  Sounds like a god-send to me. Sounds even better if we had the option for BBC rather than a compulsory T.V Licence
ajjm65
ajjm65's picture
If you go onto the freeview website there is a resolution section. it describes how some BBC channels have now moved into the 800s channel numbers. There is also a list of set top boxes that have been affected (mostly old style ones ans Sonys) with contact telephone numbers.
I'm no expert on Freeview, hope the above helps though...
Fraz1
Fraz1's picture
I set it to default settings and did a retune. That appears to have done the trick.
cheers for the advice.
__________________
bob.g
bob.g's picture
The missing channels are on a Panny 19" Viera, about one year old. Just did a complete retune and still no Freeview BBC1 or 2. The ITV channels signal strength is ~70% with a good picture. The analogue signal for BBC1 and 2 (from the same aerial) is good.
Weird !!
Diamond Joe
Glad to be of service Fraz1.
And Bob, have you tried a similar thing of setting the TV back to it's shipping condition (that's what it's called on my Panny) then retuning?
Cheers, DJ.
__________________
bob.g
bob.g's picture
Diamond Joe
Thanks for the suggestion. I tried a Factory Reset and then a reinstall, but still no BBBC1 or 2. Still  weird !!
