1080i versus 720p from SKY HD or automatic
16 replies [Last post]
anderc02
anderc02's picture
Hello, Having had a play with my new Russ Andrews/amstrad HD SKY box I am still not sure which is the best setting or HD/sd output ,is it 1080i or 720p? How can I make sure my TV is doing the upscaling as at the moment it does not seem to.Ie SD picture is 576p. Any brainwaves?
The_Lhc
The_Lhc's picture
Re: 1080i versus 720p from SKY HD or automatic
To force the TV to upscale set the SkyHD box to auto. Your TV will display 576p because that's what it's receiving from the Sky box, NOT what the TV is actually displaying (it's basically telling you you're watching an SD feed).
If that's the case you know the TV is upscaling otherwise the picture would be in a small box in the middle of the screen...
__________________
No signature worth mentioning...
Andrew Everard
Andrew Everard's picture
I leave mine set to auto, and let the rest of the system do the work. What your TV is showing is the input signal, not the on-screen resolution, which it will automatically upscale to fill the number of pixels available on the display panel.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
Andrew Everard
the_jinx!
__________________
daveh75
daveh75's picture
Online
Can't believe you you spent £600 on an RA upgraded Amstrad, but still...
Leave it on automatic, it will then output HD at it's native 1080i, and SD at 576p (you can't get a native 576i signal out of a SkyHD box via HDMI) your TV will then upscale/deinterlace...
__________________
anderc02
anderc02's picture
Thanks , will do that.
Re the Russ Andrews SkyBox; I did not spend the full amount ,I had some vouchers and they did a discount plus I got £63 for the old box on Ebay so the net outlay was £437.However It is a leap in picture quality especially SD and SKY movies it should be cheaper but is pretty good. I suppose all Hi Fi purchases are subjective and whimsy!
anderc02
anderc02's picture
Ta Andrew, you are always prompt at answering posts.
Andrew Everard
Thanks for the heads-up on the RA Sky HD box - we've just ordered up a review sample. Now we just have to sort out 200m of Kimber Kable to run to the LNB!
__________________
The_Lhc
The_Lhc's picture
anderc02:
You're welcome I'm sure...
__________________
AEJim
AEJim's picture
I just made this point on the LGPK350 thread but thought I'd copy it here, whilst the above settings may work better on some screens I found it very poor on mine. Using 1080i over HDMI all EPG menu's etc are totally crisp and clear, the picture is very decent on SD (depending on channel! Watching the Matrix on ITV the other week I actually thought it was HD until I checked the channel I was on!). When I switch to "automatic" however, everything becomes soft and indistinct, colours are poor and there is a lot of picture noise, I turned the set off and on as a check but no improvement.
As I mentioned in the other thread this could also be how the set handles freeview/freesat internally so may be why the PK590 was criticised for its SD performance in the WHF review. Via Sky 1080i the SD is as good as I would ever expect on a 50" - the closest point I would sit at in my room is about 6' and it's noise-free at that distance. It's certainly something worth checking out on your own set as one generic setting may not suit all!
__________________
Brand Manager, Acoustic Energy Ltd.
The_Lhc
The_Lhc's picture
AEJim:
All that means is that the upscaler in your TV is not as good as the one in the Sky box (which is a scary thought!). As you suggest results will be TV dependent.
__________________
AEJim
AEJim's picture
That's what I mean - it's not a universal solution for all screens! Smile Thing is my Sky box looks great on SD, the scaler seems fine in it - perhaps it depends which supplier's version you have? I have no idea why the scaler is so poor on the TV, that's why I turned it off and on, to make sure it had registered everything properly, perhaps the input makes a difference, maybe the HDMI doesn't scale the same as the other inputs... I've not heard anything bad about LG's scalers but this looks shocking on the Sky boxes automatic mode.
__________________
digigriffin
digigriffin's picture
I believe I have seen on other forums that all material is broadcast to the Sky+ HD box at 1080i?
If this is the case than any other setting to the 1080i will involved processsing by the Sky+ HD to change the resolution?
Certainly 576p is not what SD is usually broadcast at, so the box is doing something here?
I leave my box set to 1080i as with auto there is a blue screen delay in the resolution switch between HD and SD channels.
I cannot detect any improvement in my setup with auto so setting to 1080i and leaving it there
The_Lhc
The_Lhc's picture
digigriffin:
I'd be surprised if that were the case as that would mean that non-HD Sky boxes were accepting an HD broadcast and downscaling it as well, which seems unlikely, especially for older boxes that are probably still out there (like one of mine for example).
It's de-interlacing I believe (something else they're not great at either), the broadcast is 576i.
I leave my box set to 1080i as with auto there is a blue screen delay in the resolution switch between HD and SD channels. I cannot detect any improvement in my setup with auto so setting to 1080i and leaving it there
Well all I can say is I had my HD box set to 1080i for a couple of weeks after I got the TV (KRP-500a) and always felt the SD stuff looked dreadful, so I set it to auto and it was like someone had wiped a smear of mud off of the screen it was so much better.
__________________
AEJim
AEJim's picture
the_lhc:
Would be interesting (or geeky, depending on point of view) to check the manufacturer of our HDMI boxes, from memory Sky used two or three vendors. The effect I had was the exact opposite of yours oddly enough.
__________________
The_Lhc
The_Lhc's picture
AEJim:
the_lhc:
Sadly I haven't the faintest idea.
As you suggested with your comments about the WHF review of your TV I suspect it says more about the TVs than the Sky boxes.
__________________
