8 posts / 0 new
Last post
camac's picture
Last seen: 2 months 3 weeks ago
Virgin Media Volume !!!!
Curious as to why the listening volume from the Tivo Box through my av receiver is different on HD & SD channels.
I have a Tivo box in the lounge connected by hd cable to my a.v.receiver and on most hd channels (ITV hd being the exception) i have to turn the volume up on my av receiver by 10db to listen at the same volume as sd channels.
In my bedroom i have a V+ HD box connected by hd cable directly into the tv, no volume difference on any channels.
Is anyone in the same situation , or know the answer ?
Thanks.
jeff1967's picture
RE: Virgin Media Volume !!!!
hi CAMAC,
I have the same problem. According to VM forum it is due to the dynamic range of the digital signal on the HD channel.
regards,
jeff.
hammill's picture
Last seen: 1 month 2 weeks ago
The HD channels are encrypted so the Tivo box has no control of the volume for those channels - the decryption happens in the AV amp. The SD channels it can control, so you can probably get the volumes to match by reducing the volume on the Tivo box. I have the same issue with my Humax FreeSat box so the family are under strict instructions to never use the volume control on that.
camac's picture
Hi Jeff & hammill,
Thanks for the info both of you.
Just wanted to make sure the problem wasn`t my av receiver.
Thanks Guys.
Dougal1331's picture
Last seen: 1 year 9 months ago
That's odd.
On mine, the HD channels are louder than SD...
No TiVo, just standard HD box.
hammill's picture
Dougal1331 wrote:
That's odd.
Not really. Depends on what the SD volume is set to on the HD box.
camac's picture
I have found a partial solution.
If you go into "Settings" in the Tivo menu, then "Audio", then change from "Doby Digital" to "Dolby Digital to PCM".
All the volume levels are the same for both sd and hd channels.
Only problem , you wont get Dolby Digital sound on Dolby Digital HD brodcasts.
I think ?????
xerox's picture
Last seen: 3 years 3 months ago
Aha! This will be a solution for me. Thanks!  :beer:
Log in to post comments
