Tivo and Dolby Digital
9 replies [Last post]
Crossie
Crossie's picture
Help help, I`m sinking
Can I get DD 5.1 over HDMI from my Tivo box?
I can do it via optical but I get horrible pops and squeaks when changing channels on HD channels. I can only get sound via HDMI if I select DD to PCM which is only in stereo.
Virgin media are very unhelpful and I am on the verge of cancelling even though I like the Tivo features. Crying
__________________
Toshiba Netbook J River, MF V-Link 192, Cyrus Pre XPdQX with PSX-R, 4 x Cyrus Mono X's, Wilmslow Phoenix with Bass Extenders.
DandyCobalt
DandyCobalt's picture
RE: Tivo and Dolby Digital
Crossie, unless someone answers before tonight, I'll check my own machine when home.
__________________
Main: Pioneer tv + LX85, Sony HW15 Proj, Cyrus DAC XP+/Mono X300/CDXTSE2/PSXRx2, B&W CM8/CM1/PV1D, CA BD751, Virgin TiVo, Inspire Rega t/t, Benz Glider MC, EAR 834P phono amp; Slee Novo Headphone Amp
Second: Panasonic 42" E6B LED, Pioneer VSX-D2011, Kef eggs, Virgin TiVo
Crossie
Crossie's picture
Thanks DC much obliged
Crossie
__________________
Andy Clough
Andy Clough's picture
Hi Crossie, yes you can get DD 5.1 over HDMI, that's how I do it on my TiVo box. From memory I think you have to manually override the default audio setting in the sound menu, but I'll need to check at home tonight to clarify.
__________________
Andy Clough is Brand Editor of What Hi-Fi? Sound and Vision and whathifi.com
Crossie
Crossie's picture
Thanks AC much obliged.
Crossie
__________________
DandyCobalt
Just checked mine - I use Dolby Digital (not DD to PCM) in the Settings/audio menu. It automatically goes out via the HDMI.
I remember I had to check the audio input settings on my a/v receiver to ensure that it was looking at the hdmi input for sound.
I also have the optical digital audio cable connected, which is connected direct from TiVo to my Cyrus preamp, so I can listen to Spotify in stereo from TiVo whilst having blank tv screen.
__________________
Andy Clough
Snap! You beat me to it DandyCobalt. My TiVo's set up the same way. Hope that works for you Crossie.
__________________
Crossie
Crossie's picture
Thanks DC. After lots of playing around I can get sound on SD channels but not HD. I have the Tivo set to Dolby Digital and My AV receiver Marantz NR1501 set to input sound via HDMI. Still at a loss boohoo
__________________
DandyCobalt
HD channels can be much quieter - just a thought, though you've probably already tried increasing volume when on the HD ones.
__________________
Crossie
Crossie's picture
Still no luck crying
Nobody at Virgin seems to have any understanding of the Audio outputs from a Tivo box. I have made five phone calls and as yet I have not found anyone who can confirm that Tivo does support Dolby Digital over HDMI, let alone how to implement it.
Anybody know if the Dolby to PCM setting supports multi channel over HDMI on a Tivo box? puzzled
__________________
