3 posts / 0 new
Last post
landzw's picture
Last seen: 2 months 2 weeks ago
Talk Talk Vs Humax DTR-T1010
I currently have a Talk Talk You View box but its mega slow on load up, at times takes time to respond to remote and TV guide can be a little slow.
So i was thinking of replacing it with a Humax DTR-T1010 but would this iron out all the slowness?
professorhat's picture
Last seen: 1 month 1 week ago
RE: Talk Talk Vs Humax DTR-T1010
I can't say for sure as I've not used the TalkTalk box, but I have the Humax. The remote is sometimes sluggish to respond (but is okay most of the time), and the TV guide usually takes 1 to 2 seconds to populate the programmes that are on now, so this could be just the way the boxes work. Best bet would probably go to a Richer Sounds / John Lewis and see if they'll set it up so you can try it out.
On the other hand, both Huawei and Humax are bringing out new boxes (link) so might be worth holding out for them, even if just means the older ones drop in price.
The owls are not what they seem...
landzw's picture
Thanks i think trying one out like you said is the way to go
Log in to post comments
