15 posts / 0 new
Last post
admin's picture
Last seen: 3 days 2 hours ago
Sky Anytime + not working
I have activated anytime plus online and it says i now have it.
I have connected my router to sky box using home plugs which works on my friend's system with no problems but still can't get anytime + to work. any ideas?
The_Lhc's picture
Last seen: 2 months 1 day ago
RE: Sky Anytime + not working
Been a long time since I looked at those settings but have you checked the Sky box is actually connected to your router (ie has picked up an IP address and all that)?
Anonymous's picture
i will check that out. think it is but not 100%
Anonymous's picture
not sure how to check whether it is picking up an internet signal? the router is upstairs so apart from buying a 20m ethernet cable is there an easy way to find out?
The_Lhc's picture
You have to go into the settings and check whether it has an IP address listed or not. But I can't remember exactly where they are, under the services menu, have a hunt around.
moosey's picture
Last seen: 3 months 3 weeks ago
RE: Sky Anytime + not working RE: Sky Anytime + not working
have you tried turning your router on and off? on a handfull of occasions i have 'lost' anytime+ and rebooting the router has cured the problem.
I admit that i haven't used the homeplugs; i used the sky sender unit, but it might be worth a try.
good luck
Anonymous's picture
i did try a reboot but no good.
i will have a look at the services thing to see about the IP address. i'm a bit out of my depth with that though
AnotherJoe's picture
Last seen: 1 year 9 months ago
On the skybox - Services -> Settings -> Network
If the IP address starts 192.168. then its probably ok.
Needs to be plugged into the phone line as well to work fully.
When you say not working - what exactly happens when u select anytime from the planner?
Anonymous's picture
when i click on the red button to access anytime, the regular anytime comes up and not the anytime plus with all the films etc on there.
Anonymous's picture
there is an IP address showing but above it says the work 'failed' so something cleary isn't right.
sc1
sc1's picture
Last seen: 2 years 9 months ago
Have you checked your box is compatible? I have the old Thompson and it cannot do anytime +. No insult meant, just sometimes it is that simple.
Also try pluging something else into your homeplugs - to check they have synced correctly.
Pittodriered's picture
Last seen: 3 years 4 months ago
Another thing to check is that you have enabled the broadband connection for the box. I'm at work but if i remember correctly:
Options
Customise
Enable Broadband connection.
I got caught out with this when setting up my Anytime+
Anonymous's picture
thanks guys. i will have another crack at it lunchtime.
Anonymous's picture
Options
Customise
Yeee ha. Tried this and hey presto it worked. Thanks all for the help.
Log in to post comments
