6 posts / 0 new
Last post
jr1948's picture
Last seen: 1 year 2 months ago
SD Picture Size
I only watch sd for the local BBC news,tonight when i turned it on the picture only covered a quarter of the screen after checking all sd channels are the same ,all HD are fine any idea whats happened i have not changed any settings.Thanks JR
strapped for cash's picture
Last seen: 3 months 6 days ago
RE: SD Picture Size
We need to know what equipment you're using and how it's set up (including connections between devices).
jr1948's picture
RE: SD Picture Size
Hi Strapped.Glad to see you have got your tv sorted.Right i have panasonic 42gt50 new since January sky hd box panasonic blu ray aii fed into Denon amp via hdmi,as i say i have not changed any settings
robjcooper's picture
Last seen: 3 weeks 5 days ago
RE: SD Picture Size
First is your TV in Pixel for Pixel mode (screen fit)? Don't know anything about Sky boxes but it sounds as if you are seeing your SD pictures as pixel for pixel and they aren't being upscaled either by the Sky box or the TV. You may not have changed anything but perhaps sky have done a software update overnight which has changed something?
Hopefully someone else can give you some help as to checking if the Sky box is or isnt upscaling.
Rob
BIGBERNARDBRESSLAW's picture
Last seen: 6 months 3 weeks ago
RE: SD Picture Size
It's a case of settings somewhere, so start with the sky picture settings, then tv, then amp.
The answers there somewhere, just need to find it.
Panasonic TX-P50GT50 / Yamaha RX-A2020 / Panasonic DMP-BDT110 / Dali Zensor 3 / Dali Zensor Vokal / Mordaunt Short MS20i Pearl Edition / Cambridge Audio Minx 11 / Tannoy TS2.10 / Roksan Radius 5.2 / Ortofon Super OM 20
jr1948's picture
RE: SD Picture Size
Thanks guys for replies.I have just turned every thing off unplugged from the wall put it back on and yes its all back to normal should have tried this first damm sky boxes i am sure they are the cause of a lot of the picture problems people get sorry for wasting your time
JR
Log in to post comments
