How to get Sky coax through external wall easily?
2 replies [Last post]
D.J.KRIME
D.J.KRIME's picture
I've just fitted a OCTO LNB to my dish and dropped the cables but before drilling through the External wall wondered if the is a tool that assists in passing the coax through easily? also what size drill bit is best?
__________________
My usefull posts Laughing How To Calibrate Your TV
daveh75
daveh75's picture
Online
RE: How to get Sky coax through external wall easily?
http://www.ebay.co.uk/sch/?_from=R40&_trksid=p3907.m38.l1313&_nkw=magnamole&_sacat=See-All-Categories&clk_rvr_id=340794038060
You want a 10mm drill bit, if it's a single run of WF100 or similar type cable or the thin WF65 shotgun/twin cable Sky use. Or 14mm if your using WF100 shotgun/twin cable.
__________________
D.J.KRIME
D.J.KRIME's picture
Thanks Davebeauty, eh
__________________
