Help Needed Please Recording from Sky HD to DVD
6 replies [Last post]
deanosborn1
deanosborn1's picture
Am looking after some help please.
I recorded the NFL Super Bowl to my Sky +HD box and would like to transfer it to DVD for my own personal viewing.
The game/show was quite long, and to cram it all onto one DVD would result in a poor quality recording. So I thought i'd dub it to two DVD's. I have recorded the first 4 hours to the first DVD, but how can I dub the second half of the show to a second DVD from my Sky recording without starting at the beginning of the show again? Is it possible to dub from Sky HD to DVD (via scart) half way through a recording or does it always start you from the beginning of the Sky HD recording?
I spoke to someone at Sky on the live web chat but he didn't seem to understand the question.
Any help greatly appreciated.
Dean
formbypc
formbypc's picture
RE: Help Needed Please Recording from Sky HD to DVD
The Sky box doesn't allow you to fast-forward within a saved programme?
The_Lhc
The_Lhc's picture
More than that it allows you to start from any point within the program, you specify the number of minutes you want to start at.
__________________
No signature worth mentioning...
jjbomber
jjbomber's picture
I use the Sony 890 for DVD recording which has ample deiting facilities. Transfer it all over and then use A-D delete. You take take out all the adverts, half-time warbler and the power cut. That will be the thick end of 2 hours. What you have left will fit onto a single CD no problem.
BIGBERNARDBRESSLAW
BIGBERNARDBRESSLAW's picture
As The_Lhc said, you can define how many minutes in to the programme you want to start playing from.
Select the programme, press select again, then using the right arrow to the side of select, you can choose between start/last viewed/user defined/end. Select user defined, then input the number of minutes into the programme you would like to start from, then press select again.
Or alternatively, you could just fast forward to the place you want to start from surely?
__________________
LOUNGE:  Panasonic TX-P50GT50 / Panasonic DMP-BDT120 / Yamaha RX-A2020 / Q Acoustics 2020i (front) / Q Acoustics 2020 (rear) / Q Acoustics 2000Ci / Q Acoustics1000Si / Pro-Ject Debut 3 / Sky HD
BEDROOM:  Samsung LE32C450 / Sony BDP-S360 / Echostar HDS-600RS
IN THE ATTIC:  Cambridge A4 Integrated Amp (not working) / Technics SL-PG 490 CD Player / Teac V-1050 Tape Deck / Morduant Short MS-20i Pearl Edition Speakers
deanosborn1
Cheers guys.
To copy to DVD I read that you have to hit the green button to choose the COPY option, this is a pain as always starts back at the beginning of the recorded programme again.
Think I'll try the USER DEFINED option tonight.
Also I noticed with the DVD playback of the first 4 hours it had slightly squashed the picture so as to push the Sky Sports logo out of the top of the picture and the CBS Sports score box at the top it had cut in half. I've got it set to 16:9 but does this need to be changed for dubbing to DVD?
Thanks again for all the advice.
Dean
Sorreltiger
Sorreltiger's picture
You haven't said what you're using to record onto DVD, so there's no way of knowing why you're having picture format problems.  You just need to find the right place on your programme and release 'pause' on the HD box when you're ready, surely?
BTW, I wouldn't ask Sky for advice as you're not really supposed to be making copies of their programmes!
