HDMi connector to lenghthen cable?
9 replies [Last post]
ferris
ferris's picture
I currently have a 20m HDMi cable ruinning from a splitter round the outside of my house which work perfectly with no obvious loss of quality. We are moving 2 rooms around and this cable is not now long enough. My option is to replace the 20m cable with a 30m cable but a cheaper option maybe to use a connector and conect a new 10m cable to the existing one.
Is this actually possible and will i lose some picture quality??
professorhat
professorhat's picture
RE: HDMi connector to lenghthen cable?
Leaving aside the notions of will / won't picture quality be affected by different cables, you're getting into very long lengths there and therefore the realms of cables not able to transmit the data that distance before the data loss causes picture breakup / sparkles. This is even more likely if you try to connect two long leads together - the 10m cable will have been designed to transmit the data over 10m and the 20m cable over 20m - neither was designed to transmit over 30m, so although it's impossible to rule out, you're more likely to see issues.
Andrew Everard
Andrew Everard's picture
Rather than a simple connector, might be worth considering a powered HDMI repeater to connect the two cables, which will have the effect of boosting the signal.
Google 'HDMI repeater' and you'll be presented with a variety of options.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
bigboss
bigboss's picture
Online
Welcome back, Andrew! Smile
__________________
Andrew Everard
Jus' passin' through, doc – jus' passin' through...
__________________
maxflinn
maxflinn's picture
+1 .. Good to see you around  Smile
__________________
Formerly known as Ooh, Boots, etc etc...
Laptop... HTC One X....ATV3....ADM9Ts...Two German Shorthaired Pointers...
ferris
ferris's picture
Thanks for the swift replies chaps.
I've had a change of plan actually and have ordered a new Sky 1TB Box and they are throwing in 12 months free multiroom so that solves my problem.
The_Lhc
The_Lhc's picture
Eh? How the hell did you manage that?
__________________
No signature worth mentioning...
ferris
ferris's picture
i went through to the cancellation dept and said that Virgin were offering some good deals at the moment.
Was offered a 1TB box for £99, free installation and 12 months free multiroom which i thought was a pretty good deal. I had to agree to a new 12 month contract but had no problem with that.
Tonya
Tonya's picture
A small inline repeater is the way to go.
30 metres without one is pushing the boundries and the first thing you will probably notice is the unwanted introduction of "sparklies" in your picture.
__________________
Audio/video engineer based in Norway Cool
