Groan!!! darn digibox
21 replies [Last post]
plastic penguin
plastic penguin's picture
|(  banging head against wall
On Thursday we had a Sky + HD box fitted FOC by the engineer. Last night decided to rig it up to the hi-fi, and this is where the fun (not) started.
For some unexplicable reason it' will only plays out of one channel. I've connected it in the same way as the old one: Interconnects from the 'Audio' section straight to the Leema. Plus there's a heavy hum thru the speaker that doesn't work.
Any suggestions would be appreciated.
__________________
Leema Pulse MKII-S; Naim CD5i MKII; Denon TU-260L MKII; MA RS6 speakers; Pro-ject Xpression 1; loads of different cables...
Formerly known as plastic penguin
chebby
chebby's picture
Online
RE: Groan!!! darn digibox
Why not just connect the audio out from the telly to your amp?
Then you'll get the correct stereo output no matter what you are 'feeding' to the TV.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Apple iPad Mini • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
chebby
chebby's picture
Online
You haven't accidently plugged one channel into a 'component video' RCA socket have you? They are usually next to the audio L R outputs and could catch you out.
__________________
daveh75
daveh75's picture
That was my first thought.
On current Sky+/HD boxes (looking from the rear of the unit) on the far LH side, next to the fig 8 connector there are 3 vertically mounted RCAs, the bottom two are your Stereo L + R, the top yellow RCA is composite video, and to the right of those is also an orange coaxial digital out.
If your connected to the correct RCAs, I'm wondering if you've got a poor/loose connection, given the hum.
__________________
JVC DLA-X30•Grandview Cyber Series (92")•LG 50PX990•Oppo BDP-93•Humax Foxsat HDR•Humax HDR-Fox T2•Vu+ Solo²•WD TV Live•Onkyo TX-NR818•Mackie HR824 MK2•BK Monoliith DF
Sonos Connect•Studiospares Seiwin 5A
plastic penguin
It's possible - I'll double check later. Ta.
__________________
plastic penguin
Tried every possible permutation and still no joy. Even contacted Sky and they said "we're not qualified" to advise. There only seems two possible ways: Firstly, to hook up a digital (coax or Optical) from the box to the DVD player or to buy a dac. The latter I'm not keen on.
I have, nevertheless, got it working (of sorts) by connecting a lead to the TV headphone socket, but the SQ falls short of the level I'm looking for.
__________________
RobinKidderminster
RobinKidderminster's picture
Online
Surely swapping L&R leads will highlight the fault in the box or amp. Digital coax or optical will ofcourse give best sq if yr amp gives this option
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
plastic penguin
I've tried other interconnects such as the Merlin Chopins and it still doesn't pick-up the sound. Also switched inputs on the amp and still the same. CD, tuner, DVD player are fine. The amp doesn't have digital inputs, so the idea is to either run it from the box to DVD player or TV. Really have run out of ideas. (Scratches head furiously).
__________________
chebby
chebby's picture
Online
Get Sky to exchange it for a functioning HD box.
__________________
RobinKidderminster
Online
Assume L channel fault. Connect R channel from sky box to L &R in turn to amp. If all ok then repeat with L channel. Simple or maybe I am missing something. Surely its the amp faulty or the sky box? Sorry if I am not being helpful
__________________
plastic penguin
The amp isn't at fault. I've around the inputs: Tried it in CD, Tuner and Tape and all zilch. All those sources work fine. I've tried, as mentioned in the previous post, connecting from box to TV and different interconnects. The TV and DVD player works faultlessly thru the amp but the Sky box there's no sound. There is sound thru the TV speakers but not thru the amp.
Just phoned Richer Sounds and they are puzzled, too. The only suggestion they can come up with is the digital lead or a cheap CYP dac. Or both.
I've mailed the bro-in-law as he's a Sky employee. Let's see what he can suggest.
__________________
plastic penguin
Could always ask.
The digibox doesn't come with any instructions, apart from Terms and Conditions and 'How not to electricute the moggy' advice.
__________________
GSB
GSB's picture
In the meantime pp av forums have a dedicated sky forum,you might get some insight from that.
__________________
PanasonicTX-P46GT30B..Yamaha RX-A1010...Music Fidelity M3i...OPPO105EU...KEFR100/R200C/3001SE/HTB2SE...SkyHD2TB...QED Copper Speaker Cable /HDMI/Analogue...PS3...IPAD2
daveh75
daveh75's picture
plastic penguin wrote:
Could always ask.
Dont ask, insist..
If its faulty they need to replace it.
Instructions are online www.skydigi.tv/Documents/Sky+hd_manual.pdf_1314843347.pdf
__________________
RobinKidderminster
Online
A final thought to connect sky box straight into tv with red/white phono leads? Box sounds dodgy but good luck
__________________
chebby
chebby's picture
Online
Or just connect the TV to the amplifier with phono leads.
The sound from anything connected to the TV would then come through the hi-fi. (My first post on this thread.)
__________________
