Freesat conflict with Sonos?
17 replies [Last post]
benjaminlross
benjaminlross's picture
I have a Freesat enable Panasonic Viera TV. On about half the channels, it says, 'Channel not found', whereas some are fine. It does not seem to matter whether channels are HD or not. I have tried retuning it, but it makes no difference.
I thought that perhaps my newly purchased Sono/more powerful wireless router is somehow conflicting with the satellite cable? I have a lot of cables touching back there too.
Or is it more likely that it is a problem with the satellite outside?
Would appreciate any ideas, thanks.
The_Lhc
The_Lhc's picture
RE: Freesat conflict with Sonos?
Did the problem only start after you connected the Sonos/more powerful router?
__________________
No signature worth mentioning...
chebby
chebby's picture
Very unlikely to be the satellite cable. They are double screened co-axial (or should be) and there's not much in the way of RF that will break through that.
Switch off the TV. (Actually unplug it rather than just 'standby'.)
Unplug the co-ax cable from the back.
Plug the TV in and switch on (without co-ax cable).
Do a complete Freesat station scan and let it finish. (Obviously it won't find anything.)
Power off and unplug the TV from the mains again.
Re-connect the co-axial cable.
Power on TV and do the station scan again.
This usually works for lost Freeview channels and is worth a try before getting anyone out to look at the dish.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
simonlewis
simonlewis's picture
Either chebby's reply or you could go into the menu & select shipping condition this will put it into factory settings, (like from new).
__________________
formerly known as slewis ---
simon's system
benjaminlross
I believe so yes, although cannot be sure. It's a real rat's nest of cables back there, so could be any number of cables interfering with the satellite cable, but I understand that the satellite cable is pretty robust, so should not be the case.
benjaminlross
Thanks for the helpful reply Chebby. I will have a go; hopefully that will have more of an effect than just rescanning.
daveh75
daveh75's picture
If the problems started after installing Sonos/new router then it is possibly interference.
Satellite signals are downconverted by the LNB to lower IFs some of which are close to 2.4GHz part of the spectrum, so succeptable to RF interference from wifi devices, DECT phones, microwaves etc.
Should be easy to diagnose though, power off your Sonos/router and see if the signal/missing channels return
__________________
daveh75
daveh75's picture
The cable is shielded, but on tuners etc in receivers/TVs it is often poor. I've lost count of the number of service calls i've attended for no sat signal/missing channels to find routers/DECT basestations sat on top of sat receivers or tucked away behind TVs
__________________
The_Lhc
The_Lhc's picture
That's interesting, I've got my router and a Sonos ZP90 sat on the shelf below my SkyHD box, I've never encountered any issues like that.
__________________
benjaminlross
I did try turning off the Sonos, but channels are still not displaying.
The Sonos was on the shelf directly below the televions; I have now moved the Sonos to a lower shelf in the unit.
In your experience, what is the solution if it is not viable to move the Sonos/router any further away from the television?
benjaminlross
Update - Moving the Sonos down a shelf in the shelving system, away from the TV, has resulted in reception of all channels. Interesting....
hammill
hammill's picture
In your previous post who you said turning it off made no difference. How can it then help to move it down a shelf? Perhaps the moving process resolved the real problem by disturbing some cables?
scene
scene's picture
That's pretty much what I was thinking.
__________________
Hi Fi: Arcam A85, DV88 (CD only), Project Debut II, AE Compact-1. AV: Arcam AVR250, DV79, Sony BDP-S760, Monitor Audio Silver 8i, RS-LCR, RXFX, Sonos ZP90, Pioneer KRP500A. 2nd AV: Pioneer SX-SWR2, Dell Zino HD, KEF KHT2005.2 eggs, Sonos ZP90. That Cable HDMI, Chord Crimsons and Sonos ZPS5s everywhere & a spare Yamaha RXV-667!
benjaminlross
The only difference cable wise is that the thick heavy phono cable from the Sonos to the amp is no longer bunched up but instead spread out over a further distance. Otherwise the power cable and network cable running from the Sonos are in exactly the same place.
The_Lhc
The_Lhc's picture
I think they mean the satellite cables feeding the TV.
One question, when you said earlier you'd turned the Sonos off and it made no difference, did you also turn the router off?
__________________
benjaminlross
There is no difference in terms of the satellite cables.
No I did not try turning off the router.
