3 posts / 0 new
Last post
deberes's picture
Last seen: 3 years 8 months ago
freesat cable connections
Dance 4  Hi I am new to to this site and how to get help through a forum, so here goes!!!
I have a Humax Freesat box, a Samsung Digital TV and two feeds from my Satelite Dish.  Am I correct that I can record two programmes with both sets turned off i.e not on standby.  If so how do I connect/tune these devices in order to do so, please advise asap, thank you!!  Laurie dims...!
simonlewis's picture
Last seen: 1 day 14 hours ago
RE: freesat cable connections
If you connect the humax to the satellite dish & switch the humax on doesen't it automacally access the freesat channels.
Just connect them with the standered F connector plug.
OnATightBudget's picture
Last seen: 3 years 9 months ago
Should do just as Simon says plug and play. Although if you are planning on recording 2 channels simultaneously on the humax you would need to connect both sat feeds directly to that.
Log in to post comments
