9 posts / 0 new
Last post
Al ears's picture
Last seen: 4 hours 13 min ago
Freesat and old Sky dish
I have an old 'single' type Sky dish still in place on side of house. Will I have to make any modifications to it to be able to utilise a Freesat box?
Motto: Never pay full price for anything, there is always room to haggle!
Tom Evans Audio Design amplification / Acoustic Zen Adagio speakers / Dr. Feickert Analogue Woodpecker-SME310 / Oppo 105eu
Sizzers's picture
Last seen: 2 years 1 month ago
RE: Freesat and old Sky dish
As long as the LNB is okay and apart from possibly re-aligning the dish, no.
Al ears's picture
LNB is fine. Its that 're-aligning' dish that has me a tad concerned as to whether or not its worth it.
I don't no very much about Freesat so which satelite does it use if different from Sky?
daveh75's picture
Last seen: 1 week 19 hours ago
Freesat uses the same sats (Astra 2A/2B/1N and Eutelsat 28A @ 28.2/28.5 E)
Only reason for re-alignmtent would be if you're using an old dish from the analogue days, as it would have been aligned to 19.2 E. If It's an eliptical mini dish you'll be fine.
Sizzers's picture
I had some issues with my Freeview reception and hooking up the old Sky dish was a whole lot cheaper than having a complete new aerial system installed.
It probably hadn’t been used for at least 15-years, and because I needed a completely new cable run and drilling through the external wall I decided to pay to have it done. The guy had to check the LNB and was honest enough to say it was fine (I would have had no way of knowing one way or the other), and apart from spending another few  minutes re-aligning the dish the whole job was done in less than 30-minutes for £66 inc VAT.
Even if your dish did need re-aligning, depending upon it’s accessibility you could do this yourself with a signal meter costing between £5-£20. If I hadn’t needed the drilling through the external wall this is what I would have done so it needn’t be expensive.
BIGBERNARDBRESSLAW's picture
Last seen: 8 months 2 days ago
Just borrow a freesat box from someone you know to test if it will work, if it doesn't, either re-allign, new lnb, or maybe both.
I've re-alligned dishes, replaced dishes, and replaced cable in the past myself, and believe me, I'm definitely no expert.
Panasonic TX-P50GT50 / Yamaha RX-A2020 / Panasonic DMP-BDT110 / Dali Zensor 3 / Dali Zensor Vokal / Mordaunt Short MS20i Pearl Edition / Cambridge Audio Minx 11 / Tannoy TS2.10 / Roksan Radius 5.2 / Ortofon Super OM 20
eggontoast's picture
Last seen: 1 week 1 day ago
Don't worry about the dish alignment, its easy to set them up. I fitted my dish and aligned it with a cheap satellite finder, aligning the dish took about 5 minutes and took one attempt. That was with a newly fitted dish, yours will already be pointing in roughly the correct direction.
Al ears's picture
Many thanks for all your replies.
Sounds like it is a go'er then.
The dish is the newer eliptical type and the cable still exists up to the exterior wall so just need a new hole drilled and cable replaced / extended.
I'll give it a go.
motley's picture
Last seen: 6 months 2 weeks ago
Don't forget if you are buying a freesat box like a Foxsat HDR you will need 2 cables to your dish if you want to watch and record different channels at the same time.
Log in to post comments
