Considering Freevew HD Help needed please
7 replies [Last post]
Fuzzy Bear
Fuzzy Bear's picture
With the massive summer of sport coming up I've decided that I'd like to watch all the historic moments in HD and (And when England go out in the groups at least I can see fans tears in crystal clear definition)
So two questions
I live out in the sticks and currently get basic sky via satellite, do I just plug my existing aerial to my new box?
I've seen some cheap boxes £40 mark, I rarely watch tv anyway ( including Sky which may go in future) , so don't want to spend to much on what will be rarely used come September, BUT will I regret buying a cheap freeview hd box? Picture/reeption etc.
Fuzzy Bear
RE: Considering Freevew HD Help needed please
Apologies for spelling in title
simonlewis
simonlewis's picture
RE: Considering Freeview HD Help needed please
If you have a satellite dish why not use that & get freesat, you still get all the HD channels plus more FTA channels that are on freeview.
__________________
formerly known as slewis ---
simon's system
robjcooper
robjcooper's picture
Second that from Simon. If you want a cheap Freesat HD box, then these Humax 'A' grade ones are fantastic value direct from Humax.
https://humaxdirect.co.uk/product.asp?ProdRef=10070
£79.00 + £6.50 next day delivery and with a 1 year warranty. We have 3 of them in our kids bedrooms at home and they are brilliant (the humax boxes that is, not the three teenagers!).
Rob
Andrew17321
Andrew17321's picture
The BBC is offering 24 HD channels on Freesat during the Olympics, so if you are keen to see the Olympics on HD the Freesat is by far the best choice.
Andrew
Fuzzy Bear
So if I just Buy the freesat HD box, Unplug my sky box from the aerial feed then plug it into my FS HD box It will be ok, and If i want to have sky just plug aerial back into sky.
Sky wont be nasty because the satellite is technically rented or some fine print clause?
I will still be paying for my sky subscription for at least a few months anyway.
Sizzers
Sizzers's picture
It will work absolutely fine as it uses the same satellite.
The only possible "technicality" is that if your dish is under 12-months old, if you're using a non-Sky box with it they may use that as "get-out" to invalidate the warranty for it. The dish is yours regardless, and although you're paying a Sky subscription it's entirely up to you if choose to use it or not.
__________________
Putting out fire with gasoline
Fuzzy Bear
Aaaa, no much older than 12 months, and only an invalid warranty thats ok if worst comes to worst.
Thank you all.
