Calling Andy Clough
9 replies [Last post]
Crossie
Crossie's picture
Hi Andy
Please can you help me with DD 5.1 over HDMI from a Tivo box (into Marantz NR1501) With Tivo set to DD I get sound from SD channels but nothing at all from HD channels. DD to PCM works but no 5.1 only 2 ch stereo. banging head against wall
How have you managed this!
Virgin customer support is clueless.
Pleeeeeeeeeeaaaaaaaaase. Crying
__________________
Toshiba Netbook J River, Cyrus Pre XPdQX with PSX-R, 4 x Cyrus Mono X's, Wilmslow Phoenix with Bass Extenders.
Andy Clough
Andy Clough's picture
RE: Calling Andy Clough
Hi Crossie, are you saying you get no sound at all on HD channels when connecting the TiVo to the Marantz via HDMI? BTW, not all HD channels transmit DD 5.1, so sometimes you will get stereo only.
__________________
Andy Clough is Brand Editor of What Hi-Fi? Sound and Vision and whathifi.com
Crossie
Crossie's picture
Andy
Yes I understand that DD 5.1 is not always broadcast by HD channels. When set to DD output from the Tivo via HDMI I get sound on the SD channels no sound at all on any of the HD channels.
Crossie
__________________
Andrew Everard
Andrew Everard's picture
Could be an auto-detect problem between the Tivo and the Marantz. Check the Marantz's audio decoding setting for whichever input you have the Tivo connected to - if it's set to auto try 'source direct' or 'dolby'
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
Crossie
Crossie's picture
Thank you Andrew  - will give it a go. At present set to Auto on the Marantz.
Crossie
__________________
Crossie
Crossie's picture
have tried all permutations and still no sound on HD Channels.help, I`m sinking
__________________
Andrew Everard
Well, guess it could be a faulty box. Might be worth trying an optical cable between the box and Marantz, to see whether that delivers, but beyond that, and given the flakiness of the manuals supplied with both products, I'm at a bit of a loss,
All I can tell you is that I have HDMI from my Virgin Tivo to my elderly Onkyo 875 receiver, and it works fine.
__________________
Crossie
Crossie's picture
Audio works fine for standard audio and DD5.1 via optical but when changiing channels between Sd and HD I get a very loud static like click from the speakers  - very annoying and not present when using previous V+ hd box with an optical sound connection. Virgin customer services are just not equipped to answer any technical questions about the sound output from their Tivo box. All they can recommend is using PCM which is only 2 channel - not really acceptable for a flagship product.
Richard
__________________
Andrew Everard
Really does suggest a faulty box to me...
__________________
DandyCobalt
DandyCobalt's picture
+1 for faulty TiVo.
Whilst the telephone support etc is pretty rubbish, the Virgin van men have been supportive and on the customer's side  - if they have any doubt they'll just give you a new box. At least that way you can test it while they are there.
__________________
Main: Pioneer tv + LX85, Sony HW15 Proj, Cyrus DAC XP+/Mono X300/CDXTSE2/PSXRx2, B&W CM8/CM1/PV1D, CA BD751, Virgin TiVo, Inspire Rega t/t, Benz Glider MC, EAR 834P phono amp; Slee Novo Headphone Amp
Second: Panasonic 42" E6B LED, Pioneer VSX-D2011, Kef eggs, Virgin TiVo
