AV Sender
10 replies [Last post]
vpacalypse
vpacalypse's picture
I'm after an AVsender & not sure about which one will suit my purpose. I want it to output a signal from sky+hd to another TV I have which is two walls away (maybe 3 since I'm deciding to move the TV again).
I'm looking into this presently:
http://www.amazon.co.uk/Qose-5-8Ghz-Wireless-Sender-receiver/dp/B003CYYR4Q/ref=sr_1_1?ie=UTF8&qid=1349126123&sr=8-1
Any good?
Anything out there representing better techincal prowess, reliability or general 'bang for buck'? With a good review to back it up preferbly.
chudleighpaul
chudleighpaul's picture
RE: AV Sender
If you want HD on the second TV, then this will not work.
VoodooDoctor
VoodooDoctor's picture
RE: AV Sender
http://www.keene.co.uk/electronics/multi.php?mycode=GV821
This has been well reviewed elsewhere...
__________________
MA PL200s, PL350C, PLW-15, PL100s
 Onkyo PR-SC5509 -> Leema Acoustics Pyxis, Hydra II (x2) & I
JRiver 18 Leema Acoustics Elements DAC Panasonic BDT-310 PS3 X360 Wii Virgin Tivo
 Samsung PS64D8000
vpacalypse
RE: AV Sender
I want an AV sender which will transmit a HD signal. At the same time I don't want to be spending £250 odd.
Is there anything around the £50 mark?
daveh75
daveh75's picture
Online
RE: AV Sender
No chance.
__________________
vpacalypse
RE: AV Sender
Ok, what prices would I be looking at for a HD compatible one?
Links of any good ones appreciated.
daveh75
daveh75's picture
Online
RE: AV Sender
You're looking at least £140. No recommendations as the ones I've seen/tried have all been pretty poor.
__________________
D3CYPH3R
D3CYPH3R's picture
RE: AV Sender
Never tried, but what about HDMI over Ethernet? then use homeplugs to not have to use a long ehternet cable?
daveh75
daveh75's picture
Online
RE: AV Sender
HDMI baluns wont work with homeplugs/on a network, as they dont use TCP/IP
__________________
vpacalypse
RE: AV Sender
The £140 option is not my cup of tea, so I'm going with the normal qose one from amazon.
Just to be sure, the HD signal from the skybox will be turned into SD content by the time it comes up on the TV?
RobinKidderminster
RobinKidderminster's picture
RE: AV Sender
If you want SD upstairs you dont need an HD sender
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
