Am I really to get Freeview HD next March?
5 replies [Last post]
roger06
roger06's picture
I'm at a loss what / whom to beleive.
Freeview.co.uk STILL states I can't receice any digital channels, despite having had all channels with 100% signal strength since I moved to my area 8 years ago.
It states it get its info from digitaluk.co.uk. However, that site correctly tells me I get Freeview and that I'll get FreeView HD after my switch over date sometime in March next year.
Should I be excited? should I be sizing up a Freeview HD PVR?
__________________
Synology DS212J-> AppleTV->  rDAC->Naim Nait5i. Naim CD5i. Dynaudio Audience 52SE
Sony BDPS370 / YouView ->Yamaha RXV1065-> Pana TH42PX80B plasma.
chudleighpaul
chudleighpaul's picture
You ask the question, but you
You ask the question, but you don't tell us where you are, so how can we answer?
roger06
roger06's picture
RE: You ask the question, but you
Well it was more a question on the reliability of these two website...
Chichester, West Sussex.
__________________
bob.g
bob.g's picture
Look at http://www.ukfree.tv for details of what you will receive, and when
chebby
chebby's picture
Online
You've sort of answered it really.
You already get all the Freeview channels at 100% signal strength.
Unless they are going to move everything in your area to a new transmitter (unlikely) then you will be good for Freeview HD.
From March the Freeview HD channels from Rowridge (my local transmitter) are going to go out with 10 times the present power after analogue is switched off.
I'm not sure if your bit of Chichester is served by Rowridge or not. If it is, then your signal should be even better.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
roger06
roger06's picture
They've hardly made that site user-friendly have they?
These are my results - so the answer is yes to HD... I think.
__________________
