2 questions, 1 about 1TB Box & 1 regarding volume on handset!
Anyone switched from the standard Sky HD Box to the 1TB Box?
Is there any difference apart from the storage capacity?
Another quick question, my sky remote volume control seems to have stopped working so i now have to change the volume with the TV remote which is mildly annoying. Can this be rectified?? and how??
Depends on which box you currently have - The current boxes are all Amstrads and the only difference is HDD size.
If you've an older Thomson/Pace/Samsung/Amstrad there were slight H/W differences, some only had optical outputs, whereas later boxes have both optical and coaxial outputs and the early Thomsons had component outs for example.
At the end of the day though, they are/were all built down to a price, and why they aren't always very reliable.
Yes, re-programme it.
Many thanks
My 2 TVs are Panasonic and Sony, neither of which are listed on there, typical!!
So how did you manage to set it up in the first place?
Many thanks
Try using the manufacturer generic 4 digit codes and instructions for Sky+ remotes
http://www.astra2d.com/remote2.html
Those should work first time for popular manufacturers like Sony and Pana. If they don't repeat the last step of the instructions until your TVs switch into stanby (the last step toggles through all known codes for that manufacturer, untill you come to one that works)
i didn't do anything, it just worked straight away and now it doesn't!
The Sky bloke would have done it then, have you tried the destructions given above?
The code to use for sony tv's is 533.
It worked perfectly, many thanks all!!!!!
- Login to post comments
1Tb has never crashed - my old box needed frequent reboots and lost recordings. The box is slightly smaller but the capacity is brilliant - holds so many HD fims etc - well worth an upgarde IMO.
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
Base trap Project - http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
