Which portable radio as gift for wife's dad?
C
Could you please help with advice on this?
Brand with reputation for receivers
Needs to be portable for walking trips and the like
ideally international FM bands plus other bands
excellent build and reliability
no budget limit
Hope it's not tooo late
I know one good site which sells portable radios. I came across it when searching for a present for my friend. Finally I bought VX-350 Series for him. My friend is crazy about travelling so he always takes this radio with him. The battery life is quite long. By the way, this is one of the first things to consider while buing a portable radio. Of couse, such radios are more expensive but they worth it
http://www.vitaaudio.com/products/r1
http://www.whathifi.com/review/vita-audio-r1-mkii
With the optional leather carry case and rechargeable battery back this should fulfil your criteria. It also has DAB and DAB+ as well as FM.
The company has excellent credentials as it was originally Ruark. (Who made great hifi speakers.)
If you want something smaller like a world-band radio (FM + AM + SW) then the best in my experience is the venerable Sony ICH-SW7600GR. (I had one for about ten years.)
It is about the size of a 300 page paperback novel and so fairly portable. It also has 'line-out' (stereo) so you can plug it into a hifi as a respectable mini hifi tuner (if FM reception is good). It comes with a soft case and a spooled short-wave antenna too.
http://www.sony.co.uk/product/por-world-band-receivers/icf-sw7600gr
Hi
Buy the Avanti Pure it has everything!!
Paul.
You will have to be very fit to take that on your walking holidays.
- Login to post comments
Very happy with my Evoke 1S Marshall. It's got DAB, FM, headphone out and a 3.5mm Aux input, takes a Chargepak so works happily mains-free (had mine using the battery all day with no problems before now). Has a robust carry handle and (specific to the Marshall edition) beefy corner protectors. If he ain't a rocker/guitarist there are always the regular wood finishes of the rest of the 1S range.
Of course, if you're talking personal rather than portable, the 1S may prove a tad bulky.
Hi-Fi: Arcam A85, P85, CD192. B&W 602S3, PV1, Grado SR125, Atlas Titan, Hyper 2.0.
A/V: Sony KDL-V40A12U, BDP-S760, Humax Youview, Onkyo TX-SR875, B&W MT30 7.1, QED HDMI-P, S.A XT
