4 posts / 0 new
Last post
sthomas048's picture
Last seen: 1 month 4 days ago
Vintage Tuner help
Hello all,
Im at the point of buying an olde vintage tuner and I notice the aerial inputs are screw type. Where on earth do I find a good indoor aerial that has bare wire connectors ?
Also looking at the Leak Delta tuners Im even more confused, here is a pic -
Is this a modern aerial input that I could plug my current desktop indoor aerial in ? I would greatly appreciate any help with this.
Kind Regards.
Stephen
MajorFubar's picture
Last seen: 6 hours 2 min ago
RE: Vintage Tuner help
Looks like a normal 75Ω connector to me, and is labelled as such. What am I missing?
Audio: MacMini / AEX > AVI DM10 + BK Gemini II sub; Visual: Samsung BD-C5500 > Panasonic TX-L47ET5B.
Head-fi: various, but most often Sennheiser HD-580 or Audio Technica ATH-M50X
Yeh I wasnt 100% sure. But thanks anyway. So its a standard aerial input ?
Yep more or less. Just to confuse things, on tuners they sometimes put the male plug on the tuner which fits into a female socket on the aerial lead, ie opposite to a TV. Try plugging your TV aerial into it to see if it fits, that way you'll know whether you need a plug or a socket. In fact I'm surprised you didn't just do that in the first place, it's quicker than starting a thread about it.
Log in to post comments
