seperates DAB tuner...arial?
5 replies [Last post]
GSB
GSB's picture
Hi guys,
Thinking of adding a DAB/FM seperates tuner,can someone confirm if i need a roof mounted arial?
cheers
__________________
PanasonicTX-P46GT30B..Yamaha RX-A1010...Music Fidelity M3i...OPPO105EU...KEFR100/R200C/3001SE/HTB2SE...SkyHD2TB...QED Copper Speaker Cable /HDMI/Analogue...PS3...IPAD2
Andrew Everard
Andrew Everard's picture
RE: seperates DAB tuner...arial?
Unless you're in an amazingly strong signal area, yes an outdoor aerial is a good idea.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
GSB
GSB's picture
Thanks for your reply Smile
__________________
Andrew Everard
No probs – an external aerial needn't cost a fortune: I'd get a local CAI-member company to quote. If you look under 'members' on the CAI website, there's a postcode search facility
__________________
GSB
GSB's picture
Thanks.
__________________
8009514
8009514's picture
If you are in an area with good reception you may find your TV aerial will work just fine with DAB. Worth a try before you get aerial fitters in.
Rich
__________________
Marantz MCR603, Maplin mutistrand OFC, MA BR1s, AKG K44 • Pana TX-32LXD70, Pana DMR-EX769, V+, Thatcable HDMIs, Tacima • Dansette and HMV wind up gramophone.
