Pure chronos idock thingy.
9 replies [Last post]
Big Chris
Big Chris's picture
Was thinking about a pair of these for mine and The Wife's alarm clocks. Replacing some Sony 'Dream Machine' clock radios.
Firstly. Will she be able to use her first gen Nano on it?
What's the DAB reception like? I live out in the sticks a bit, but my One Classic works fine with the aerial extended.
Does it come with a length-of-wire type aerial, a telescopic aerial, or does it need an external aerial?
Thanks.
__________________
Hi-Fi: Arcam A85, P85, CD192. B&W 602S3, PV1, Grado SR125, Atlas Titan, Hyper 2.0.
A/V: Sony KDL-V40A12U, BDP-S760, Humax Youview, Onkyo TX-SR875, B&W MT30 7.1, QED HDMI-P, S.A XT
Big Chris
Big Chris's picture
Re: Pure chronos idock thingy.
Well Chris.
You/I have just bought the CD version of the above (no dock). The DAB reception is great. No negatives here (it uses a length of wire type aerial.
You/I may well still buy the idock version for the Mrs and see if the first gen Nano works on it (I believe it does.
__________________
John Duncan
John Duncan's picture
Didn't see this, or I'd have told you that it sounds good, it has a length of wire, but that I have the CD one so can't comment on iPod compatibility...
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
Big Chris
Big Chris's picture
John/Anyone else.
I imagine you're using this as a bedside alarm clock, but just in case you're using it in an office/kitchen.
Have you noticed any high pitched, low volume sound coming from the plug?
A couple of nights after setting it up, I woke up to this sound that I couldn't place. A "tinging" sound (No it wasn't The Ting-Tings). After laying there thinking maybe it was the fridge playing up downstairs, I pinpointed it to the Pure's plug. It was late, so I turned it onto it's back (It's on an extension bar) and the noise seems to have stopped. Bit odd. I've heard it one other night too, so has the Mrs, so it's definitely not Tinitus. A quick smack stopped it this time.
I got it from Play, so can't be bothered with the whole returns rigmarole.
Dunno if any other PSUs will work with it.
__________________
John Duncan
Ooo. Now you've freaked me out. This was a few weeks (or even months) ago, but there was a high-pitched whining in my bedroom (and no, it wasn't Mrs JD saying she had a headache), which I couldn't locate...
__________________
Big Chris
Big Chris's picture
JohnDuncan:
Pound to a penny it's the Pure's plug.
__________________
John Duncan
Yep. Should be easy enough to get another PSU, provided you know the voltage and current req'd...
__________________
ESP2009
ESP2009's picture
I'm pretty sure I have seen this 'fault' mentioned elsewhere - do an internet search regarding the gizmo and I'll think you'll come across this phenomenon spoken of. I thought of buying one for just the same purpose and decided to leave it a while after seeing some of the comments. I don't fancy being on the bleeding edge.
__________________
Naim Uniti (24/192); ProAc Studio 140 Mk2 ; Synology DS212j & Logitech Squeezebox Touch (it's a kind of magic!) ; Fewer boxes and stringy bits than previously. Subject to change at a whim or WHF delivery.
Big Chris
Big Chris's picture
JohnDuncan:
Manual says 9v 1.5a. Easy to come by if it proves to be a persistent issue.
__________________
rob_981
rob_981's picture
I have the Pure Chronos idock, and I noticed a very faint, high pitched beeping sound. For the first few nights, I couldn't work out what it was (I thought it was an alarm or something way in the distance) and it was doing my head in, but when I moved it downstairs, I could still hear it. I eventually figured out that it was coming from the player itself. Bit annoying, but I can certainly live with it.
 Don't know about its compatibility with Ipod nano 1st gen (as I don't have one), but I will check on the side of the box when I get home and see what it says, if you haven't already got one.
