one box solution to getting 320k Radio 3 stream?
4 replies [Last post]
Kevin Stephens
Kevin Stephens's picture
I'm looking at internet radio options as an alternative to upgrading my FM tuner. This would depend on Radio 3 320k web feed. I understnd that normal internet radio that you can get using an M1 Clic or similar only gives 192 kb. Is there an alternative solution of product that would not require me to use my laptop (which may be busy on other stuff)?
I guess one solution would be to buy a cheapo pc and connect direct to my cable modem and a DAC, would this be a sensible option that could also access standard Internet radio stations and cheaper than an M1 Clic?
__________________
Musical Fidelity A3.5 CD, A3.5 int amp and A5 FM/DAB tuner, Monitor Audio GS10s, Chord Chorus 2 and Odyssey 2
John Duncan
John Duncan's picture
Online
RE: one box solution to getting 320k Radio 3 stream?
I'd expect most internet-radio enabled devices to be able to get the 320k Radio 3 stream, though I'll need to check mine...
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
Kevin Stephens
AFAIK Nope, the 320k stream is only channeled through BBC iplayer unlike it's 192k service which goes through the normal internet radio chanels.  For example overseas users can't access the 320 k feed
__________________
John Duncan
Online
Right I just checked my Stream Magic and the Radio 3 (AAC) stream says 320k. I also seem to recall adding it to the Uniti via vTuner. This suggests a number of other things will do it like the NP30 or UnitiQute, but can't speak for Squeezebox or others...
EDIT - the squeezebox forums seem to suggest that the iPlayer plugin supports 320k too, though this was a while ago; don't know if anything has changed in the stream itself that might prevent it now.
__________________
chebby
chebby's picture
Online
Kevin Stephens wrote:
AFAIK Nope, the 320k stream is only channeled through BBC iplayer...
I have just checked BBC R3 on my TuneIn Radio Pro app (on my iPhone). The app has a 'Choose Stream' option. When I click on this, it presents 'Listening Options'.
320 kbps AAC is the first of 4 options listed (and it was already selected by the app so it must default to it).
Even via AirPlay (to my M-CR603) it sounds superb.
As far as I know TuneIn Radio Pro doesn't stream from BBC iPlayer.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
