How best can you record a digital radio station
4 replies [Last post]
Pete Shields
Pete Shields's picture
Many years ago, as a teenager, I was a big fan of Radio 1's in concert series. I would tape my favourite gigs on C60's or C90's and would play them until they wore out or snapped!
Things move on. In concert has moved to Radio 2 and now my teenage son is the real gigger in the house...
Anyway, he went to see the Script in Liverpool on Monday, and the concert will be on Radio 2 this Thursday.
The old tape deck is gathering dust in my loft, so I want to use my PC to capture this gig for posterity. Any suggestions on the best way of doing this?
nads
nads's picture
RE: Digital and analogue radio
download a an audio program of your choice onto your computer and press record.
burn to CD later if needed.
__________________
Not a HiFi Nut. Just has a pile of Nads.
unfocused
unfocused's picture
Aren't there some DAB radio's that you can put a USB stick or a SD memory card to record programmes on?
iMark
iMark's picture
There's a couple of options depending on the gear you have.
I sometimes us our Sony DVD/HDD recorder for recording FM. The Sony is connected to my stereo receiver. I can set the timer to record from Line In 4. I can transfer the music to my Mac buy burning a DVD. Only caveat is that the files are in AC3 and need converting first.
For recording digital streams over the internet I use Audio Hijack Pro on my Mac. Of course I can also use that software to record from the stereo receiver. I sometimes use that with my Griffin iMac, which basically is a USB sound card. Audio Hijack Pro comes with a timer too.
__________________
MacBook, iTunes (ALAC), Airport Express, Cambridge Audio DACmagic, Denon DRA 1000, Infinity Overture 1 speakers, Sony KL40HX750, Sony BDP-S-590, Humax iHDR 5200c, Pro-Ject 1Xpression III Comfort with Ortofon 2M Red
Cofnchtr
Cofnchtr's picture
If you have SKY+ you can record from there IIRC? Channel 0102.
Cheers,
Cofnchtr.
__________________
Panasonic TX-50GT30B | Pioneer VSX-LX53 | Pioneer BDP-LX54 | B&W M1 x 5 | REL Strata | SKY+HD 1TB | Harmony One Remote | Contentment.
