DIY Aerial question
8 replies [Last post]
theadmans
theadmans's picture
I have just bought a Revo Pico radio but it only comes with a telescopic aerial and no socket for an external rooftop aerial.
This is disappointing as Pure Dab radios have the option to unscrew the telescopic aerial and connect an external aerial.
I just wondered if someone can suggest how I might connect a rooftop aerial to the Revo - is there a way of doing this with some sort of DIY lash up?
8009514
8009514's picture
Re: DIY Aerial question
I can only think of something I did many years ago. Make a tube, paper/cardboard or whatever, which can only just slip over the telescopic on your Revo. Wrap a lot of turns of thin wire around it, then connect other end to centre connector of outdoor aerial socket. Its not great or particularly nice looking, but it worked for me when I was in the middle east. Enabled me to pick up BBC Worldservice pretty well and a load of other radio signals as well. That was Short wave signals I was trying to get though. How it'll work for Dab reception is anybodys guess. Might be worth a try and certainly won't cost much.
 It worked a lot better than just connecting to the telescopic aerial with a crocodlie clip!
Rich
__________________
Marantz MCR603, Maplin mutistrand OFC, MA BR1s, AKG K44 • Pana TX-32LXD70, Pana DMR-EX769, V+, Thatcable HDMIs, Tacima • Dansette and HMV wind up gramophone.
theadmans
theadmans's picture
8009514:
Rich
Thanks Rich that is exactly the kind of "lash up" I was thinking of !  - I'll give it a try.
8009514
8009514's picture
Let us know how it goes. If its a stunning success I'll try to patent it and flog them through Maplins or somewhere.Big Smile
Rich
__________________
visionary
visionary's picture
8009514:
Rich
Nah! Try for Dragon's Den
__________________
Sonos ZP90>Missing Link "Digit">Dacmagic>Chord Cadenza>Leema Tucana I>Van Damme UP LC-OFC>ATC SCM40s
johnnyjazz
johnnyjazz's picture
visionary:
8009514:
Rich
Am no investin so am owt Indifferent
__________________
fayeanddavid
fayeanddavid's picture
theadmans:
Are you sure you can't unscrew the telescopic aerial, had the same issue on the Cambridge One I bought, unscrewed the aerial and replaced with an "F" fitting I think, which will take a coax lead, ran a couple of meters up the wall, refitted the telescopic aerial, hid some of the DIY away and now have reasonable DAB reception
I do admit that Cambridge included the special hex fitting tool to do the job, however it has worked out well
__________________
Lounge: Sony 52W5500, Yamaha RX V2700, Sony S390 BDP, Sky+ HD 1TB, KEF R500/R600C/T301 rears, Chord Odyssey and Carnival for rears, Chord ProDac/HDMI, Chord Power Chords,  BK Monolith DF
Family: Cambridge One, Rega P3-24 Elys 2, Mission 771e, Chord Carnival cable
Various: MacBook Pro, HP Pavilion dm4,  iPod docks,  iPhones, 160GB Classic and various generation Nanos
theadmans
theadmans's picture
No F type connector a la Pure I'm afraid.
I have tried the Wire lash up suggested by Rich and yes it does work !
Now on Dab instead of bubbling mud I have a signal strength of around 80 most of the time - thanks.
8009514
8009514's picture
Great, now applying for patent, new company to be formed (probably called 'LashUps R Us'). First product likely to be the 'Audiophile DAB Enhancer'
Glad it worked for you. Yes
Rich.
__________________
