DAB Vs Virgin cable?
6 replies [Last post]
Kevin Stephens
Kevin Stephens's picture
I enjoy R3 etc on FM but DAB only stations like Radio 6 don't give me the sound quality I would like, despite my DAB tuner and roof aeriel being as good as it gets,. I'm wondering if investing in basic DAC like the V-DAC2 to import Radio 6 etc from my set top box would provide much of an improvement?
I have no intention to connect my computer to my HiFi for internet radio
__________________
Musical Fidelity A3.5 CD, A3.5 int amp and A5 FM/DAB tuner, Monitor Audio GS10s, Chord Chorus 2 and Odyssey 2
Dougal1331
Dougal1331's picture
RE: DAB Vs Virgin cable?
That depends. The ultimate limiting factor is the bitrate of the broadcast.
I have Virgin Media, the box is linked in via standard analog phonos to my hifi system, and I have to say the sound quality is very good, full-bodied and fairly detailed.
Whether it would give a more 'preferable' sound in your case would be entirely down to your own ears.
If I were you, I'd grab a spare pair of ICs and try the analog outs first before splashing out on a DAC... You may be pleasantly surprised.
EDIT  Pretty certain I had to use a Scart adaptor as the box doesn't have its own phono-outs. These only cost about a fiver...
__________________
Arcam CD72, Rotel RA02/RB03 biamp, TDL Studio 0.5 (or Wharfedale Coleridge- currently undergoing surgery...), QED Revelation s/c, Qunex 4S ics.
PC- Optical to Audio Alchemy DDEv1/Rotel RA935BX/Mission 780/VanDamme Studio Blue 6mm
londonman
londonman's picture
Are you sure about the actual source material?  I know that many DAB commercial stations transmit at abysmally low bit-rates and some even in mono.  Any idea what bitrate the BBC uses for Radio 6?  And is it consistent or does it drop when they need to pinch bandwidth for another channel?
60kHz bit-rate and mono.   ":DAB gives you better sound quality" lied Digital Radio UK.
londonman
londonman's picture
60kHz bit-rate and mono.   "DAB gives you better sound quality" lied Digital Radio UK.
chebby
chebby's picture
BBC Radio 6 is 128Kbps AAC via the internet. (And in stereo of course.)
Internet is always better than DAB.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
jjbomber
jjbomber's picture
PlanetRock is 32kbps and awful on the internet, but a lot better on Sky. Maybe now that they have been taken over we may get an improvement. RockRadio1 is at 192Kbps and much better.
chebby
chebby's picture
PlanetRock is 64Kbps AAC (90 percent reliable) here using TuneIn Radio Pro.
Sounds ok.
RockRadio1 is 192Kbps MP3 (99 percent reliable).
__________________
