DAB separates tuner
9 replies [Last post]
richardjlarby
richardjlarby's picture
Last night I actually found something on the radio worth listening to. On the odd occasion that this happens I use the tuner in my Bravia. Not that it sounds terrible or anything, but, how much better can a dedicated tuner sound?
Andy Clough
Andy Clough's picture
Re: DAB separates tuner
Considerably, is the simple answer, although of course it depends which amp/speakers you're playing the tuner through.
__________________
Andy Clough is Brand Editor of What Hi-Fi? Sound and Vision and whathifi.com
richardjlarby
I was looking at the sony st-sb900 to match my sony str-db930, playing through Q acoustics 1050s in stereo.
Andy Clough
Sony tuners are usually pretty good, although we haven't tested this particular model yet. But it should certainly sound better than digital radio on Freeview played through your TV speakers.
Depending on where you live, you may well need to invest in a decent DAB aerial to get the best out of the tuner, as DAB signal strength can vary enormously around the country.
__________________
richardjlarby
I use the RCA outputs on my TV to link it to my amp, not into listening through my tv, especially not to music. I get some bad interference sometimes too. im going to finish this rant in off topic and misc.
lazaroonie
lazaroonie's picture
Best 40 quid I ever spent was getting a dedicated DAB aerial fitted in the loft in place of the TV aerial - I live in a new build house, and it means that all the aerial output points in the house can now feed to DAB radios.
oh, and for a cheap DAB, the bush seperate from Richer Sounds at 60 quid is hard to beat. not a name I would normally buy.
richardjlarby
No offence to anyone, but, I don't think I could face having a Bush.
louisv6
louisv6's picture
As I understand it the bandwidth available for Digital Freeview radio is higher than DAB. This theoretically should mean that the quality of the sound should be better.
Of course the quality of the tuner and componentry comes into play, and I would guess that more time and effort has been spent on extracting the best noise from a dedicated DAB unit than from your average freeview tuner.
Andrew Everard
Andrew Everard's picture
If you have a TV with digital output it might be worth experimenting with a budget digital lead - probably optical, being a Sony. The DACs/analogue section in AV receivers usually much better than those in TVs.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
kelly rowlands
kelly rowlands's picture
I have my cambridge audio 640Tv2 Dab tuner connected to my tv roof aerial,i have a 2 way splitter connected to the end
of the incoming lead, and then a fly lead to the tv and one to the tuner,the reception is exellent.
