DAB Roof Aerial
4 replies [Last post]
Baldybonce
Baldybonce's picture
I have a Denon DM-37. Use it alot for listeneing to Dab radio. How much better would a rooftop aerial be? Anybody out there got one and roughly how much are they? Merry Xmas everybody!
8009514
8009514's picture
Re: DAB Roof Aerial
What are you using at the moment? I assume a length of wire.  You could try splitting your TV aerial feed and connecting to your DM37. Most TV aerials are wideband enough to pick up the DAB signals pretty well. Works just fine for me, but a lot depends on how good your reception is.
__________________
Marantz MCR603, Maplin mutistrand OFC, MA BR1s, AKG K44 • Pana TX-32LXD70, Pana DMR-EX769, V+, Thatcable HDMIs, Tacima • Dansette and HMV wind up gramophone.
fayeanddavid
fayeanddavid's picture
Re: DAB Roof Aerial
8009514:
Would then also apply for FM as well, i.e. TV aerial being used for FM??
__________________
Lounge: Sony 52W5500, Yamaha RX V2700, Sony S390 BDP, Sky+ HD 1TB, KEF R500/R600C/T301 rears, Chord Odyssey and Carnival for rears, Chord ProDac/HDMI, Chord Power Chords,  BK Monolith DF
Family: Cambridge One, Rega P3-24 Elys 2, Mission 771e, Chord Carnival cable
Various: MacBook Pro, HP Pavilion dm4,  iPod docks,  iPhones, 160GB Classic and various generation Nanos
8009514
8009514's picture
Re: DAB Roof Aerial
fayeanddavid:
Well for FM you might get away with it. Worked for me, but I have some really good signal levels from my aerial. DAB is broadcast at about 220MHz which most wideband TV areials can pick up..
FM, however is down at 88 - 108MHz which really is outside the design of a TV aerial. It worked for me though so no harm in trying.
__________________
romseyraver
romseyraver's picture
Re: DAB Roof Aerial
I have connected my Onkyo to my freeview tv aerial and it works perfectly - well as perfectly as DAB ever gets.  Can't pull off the same trick with FM, as it needs a different type of aerial.
