Any recommendations for...
5 replies [Last post]
plastic penguin
plastic penguin's picture
...a Denon TU-1800? Like Chebby I listen to a lot of radio, and recently purchased a 260L, which sounded good. This has now found another home with a charity business near me.
Has anyone owned or heard the 1800? if so, how does it stack up against the 260L?
*EDIT* I can edit mine anytime. hello or goodbye
__________________
Leema Pulse MKII-S; Naim CD5i MKII; Denon TU-260L MKII; MA RS6 speakers; Pro-ject Xpression 1; loads of different cables...
Formerly known as plastic penguin
chebby
chebby's picture
Online
RE: Any recommendations for...
Have the reception problems been sorted out now?
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
plastic penguin
Certainly the slight sibilance cleared just before the other Denon was delivered. As it was cheap as chips I decided to keep it. Now have the Marantz rigged back up and it sounds fine.
__________________
chebby
chebby's picture
Online
If I were starting with your
If I were starting with your set-up, i'd be tempted to get another cheap Denon TU-260 (for FM) or keep the Marantz going and spend £99 on an Apple TV.
With an iPod Touch (plenty of good used ones) or iPad Mini you can then get iPlayer Radio app and TuneIn Radio Pro and (using the AirPlay that is built into both devices) have a wireless 'Uber tuner' that fits in your palm that can have radio podcasts downloaded, live Radio, catch-up radio and plenty of other tricks too.
__________________
BenLaw
BenLaw's picture
I used to own the TU-1800. It was very good, stacked up favourably against the Primare T23.
__________________
HiFi   /   A/V   /   Bedroom
plastic penguin
Not sure I want to go Apple TV route at this stage, purely because I get a whole heap radio stations on Freeview + tuner, although it's an option for the future.
__________________
