will airport express
Thu, Jan 1 2009, 4:08PM
Play my sons new nano if hooked up to our imac.
Many thanks
Sat, Jan 3 2009, 8:35PM
#2
yes if you're playing the nano via itunes my g/f does it with her ipod all the time when she can't be bothered plugging in the external hdd.
Sat, Jan 3 2009, 10:05PM
#3
blackcabmal:Play my sons new nano if hooked up to our imac.
Many thanksÿ
That depends on whether his nano is synced to your library? If not, the first thing it will do is ask you to erase the contents......
If it is though, why would you want to, since all the music is on the iMac in the first place?
- Login to post comments
Hi, not quite sure what you are asking here...
The AE takes the sound from itunes on the mac, and plays it through it's 3.5mm jack (either optical digital or analogue) using a wireless network as the transport.
So basically it's a way to get the sound from your imac to a stereo in another room for example.
Can't see where the nano comes into it...
Sources: Technics SL1210Mk2 with Denon DL110/AT-95E, Mac Mini, Virgin V+.
Amplification: Cyrus 2.
Speakers: Mordaunt Short MS20i Pearls with Fisual Super Pearl 2.5mm cable.
Other kit: More than I should have. My loft is creaking.
