Why different bit rates after ripping
13 replies [Last post]
Brisk
Brisk's picture
Im currently in the process of ripping my entire CD collection into FLAC and have noticed that the bit rate is smaller after ripping then on the cd. As long as this isn't going to affect the sound I don't mind but wondered if anyone knows why?
Craig M.
Craig M.'s picture
Re: Why different bit rates after ripping
i've noticed that also and came to the conclusion simpler music doesn't need or get the full bitrate.  just a guess though...
__________________
Synology NAS + Audio Station - ATV2 - Benchmark DAC1 HDR - Event Opal
http://nwavguy.blogspot.co.uk/2012/04/what-we-hear.html
manicm
manicm's picture
Brisk:
Although FLAC is 'lossless' it encodes at max about 900k
__________________
Arcam Solo Mini/Monitor Audio RX1/Cambridge Audio 751BD/Samsung 37” LCD
chebby
chebby's picture
When I look at word length and sampling rate of my Apple Lossless files they are 16 bit and 44.1 khz.
'Bit rate' (on a randomly selected Roy Orbison track) is 909 kbps. (iTunes)
What should it be?
Edit: just randomly selected another track (Blondie) and it is 983 kbps
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
John Duncan
John Duncan's picture
Online
chebby:
What should it be?
It averages them out depending on how much information is actually on the track....
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
manicm
manicm's picture
JohnDuncan:
chebby:
When I look at word length and sampling rate of my Apple Lossless files they are 16 bit and 44.1 khz. 'Bit rate' (on a randomly selected Roy Orbison track) is 909 kbps. (iTunes) What should it be? Edit: just randomly selected another track (Blondie) and it is 983 kbps
John, on forums on another website some think that iTunes is not good enough even as an Apple Lossless encoder since they believe it does not perform error-checking or re-sampling on poor discs like EAC + AccurateRip, what are your views on this?
__________________
John Duncan
Online
manicm:
JohnDuncan:
chebby:
It does perform error checking if you switch it on in Preferences, but you're right - there's no way of checking that you have a bit-perfect copy like with EAC. Now I rip discs as soon as I get them so I don't really consider this an issue, but since I have a Mac and neither EAC nor dbPoweramp work on it, it's the best I can get, short of running Windows under Boot Camp. And seeing as it sounds better than my CD player, I'll take that.
__________________
PJPro
PJPro's picture
Could always rip on a windows pc using EAC and then convert to apple lossless.
I'm assuming here that there is a tool available to do the conversion.
The one issue here, of course, is what to do when EAC tells you it cannot perform a bit perfect copy. I had this recently with a new, unplayed CD. I tried cleaning it, etc, but couldn't get the last 3 tracks to rip perfectly. In the end, I used dbpoweramp to rip these tracks imperfectly.
__________________
My useful(?) What HiFi Forum threads can be found here.
John Duncan
Online
PJPro:
Yeah, Max will convert between the two, I think, but life's too short Big Smile
__________________
Alec
Alec's picture
JohnDuncan:
PJPro:
Will convert between the 2 what...?
__________________
Formerly known as al7478...
HC: Panasonic PXP 42 V20; Panasonic DMP BD35; Humax Foxsat-HDR
Music: Optical out from Asus P7H55-M Motherboard into AVI ADM 9.1 speakers.
"Music will provide the light you cannot resist"
John Duncan
Online
al7478:
JohnDuncan:
PJPro:
Apple lossless and Flac.
__________________
Brisk
Brisk's picture
It seems to be varying by track, some I get 1195 and others only 580, I guess it depends on the content of the tracks. Most CD's show up as 1411kbps. But your right, life is too short.
Eddie Pound
Eddie Pound's picture
A 16/44 WAV will be 1411
16/44 Apple Lossless and FLAC will be anything upto that.
Very simple music could be as low as 400kbps whereas noisy rock might be nearer 1400kbps.
It's lossless, and iTunes is lovely, so don't worry.
Alec
Alec's picture
JohnDuncan:
al7478:
JohnDuncan:
PJPro:
AHA! Great point well made sir!
__________________
