What file type & media player would you suggest for best possible sound from PC
59 replies [Last post]
Monkeyboy3001
Monkeyboy3001's picture
I'm finally going to start using my PC as a source, CD & Vinyl will always be my main sources so I'm not looking to remortgage, my main spends will be the DAC, decent USB lead & interconnect, which will be about £250. I need some advice though:
1) I plan on getting a decent DAC, looking at the Fubar 2 from Russ Andrews at present, any other sugestions? This DAC bypasses the sound card so negates spending on a decent soundcard.
2) What media player should I use? I currently use windows media player & like it, but are there any sonic benefits to using something else?
3) What format should I store my music in? From looking at the options in windows media player it looks like WAV is the way to go, am I right? I've heard people talking about FLAC files, whats the deal with these?
Any guidance would be greatly appreciated.
Richard
idc
idc's picture
Re: What file type & media player would you suggest for best
Monkeyboy3001:
1) I plan on getting a decent DAC, looking at the Fubar 2 from Russ Andrews at present, any other sugestions? This DAC bypasses the sound card so negates spending on a decent soundcard......
I use the Fubar and its Supplier, which I finds ads greater dynamic to the sound, Forget spending any serious money on a USB cable, I have tried three and cannot hear a difference. As for an interconnect the SHB is still cheap and highly recommended. Your budget will then streatch to the Fubar with Supplier, particularly if you buy from Firestone Audio direct.
Monkeyboy3001:
I use WMP and itunes and cannot tell the difference between them. Ease of use is about the same as well, but itunes gives you access to their store and films etc for the future. You do not need to pick and stick to one because of the availability of file converters. Download both and any others you fancy then import a CD (keep the bit rate the same for a fair comparison) and see if you can hear a difference. Then download a few tracks and again see if you can hear a difference.
Monkeyboy3001:
3) What format should I store my music in? From looking at the options in windows media player it looks like WAV is the way to go, am I right? I've heard people talking about FLAC files, whats the deal with these? Any guidance would be greatly appreciated. Richard
Once you have decided which media player you are going to use, use the highest bit rate possible in that file type. After saying that I struggle to pick out the difference between 320kbps and higher bit rates. Sometimes and album imported/downloaded at a lower bit rate sounds a bit flat. I assume you have no storage space issues.
__________________
Internet - laptop - DAC - amp - lots of headphones.
http://idc1966.blogspot.co.uk/
"A music lover will stop what he's doing and stay glued to a favorite piece of music even if it's coming over a 3" speaker or a public-address system..." - Ken Rockwell
Monkeyboy3001
Thanks for the speedy response idc, very helpful. When you say the Fubar & its supplier, what do you mean by 'supplier'?
I have 4GB memory, I think this will get me started but I can add more if needed.
Richard
kena
kena's picture
idc meant  disk storage space Richard - A FLAC file is a lossless compressed file  so it takes less space on your hard drive. Basic WMP doesn't play FLAC but you can easily download the required codec to allow it (Just google Playing flac in WMP) Itunes doesn't do FLAC so If you use that you would have to choose another lossless format.
Messiah
Messiah's picture
Monkeyboy3001:
There is an upgraded dedicated power supply. I think this is what he is referring to.
__________________
System Photos | Netbook (iTunes) | Onkyo ND-S1 | AVI ADM 9.1 | Yamaha Sub | Epoz Aktimate Mini
PJPro
PJPro's picture
The media players shouldn't sound any different (if they are any good at all). The choice is more to do with file type, convenience, features and resources available. Your choice can also be influenced by whether you want to use corporation or online community offerings.
Some media players offer the ability of use plugins to by-pass some of the windows processing eg ASIO, Kernal Streaming, WASAPI, etc. If you want to use these features (better sound quality) you'll need to go for a media player that supports them.
Me? I use FLAC with Foobar2000. I used to use MWP but it ended up annoying me (I still use it to stream photos to my PS3). I tried Winamp and a few others but none offered the flexibility, features or were as resource light as F2K.
__________________
My useful(?) What HiFi Forum threads can be found here.
idc
idc's picture
Monkeyboy3001:
..... When you say the Fubar & its supplier, what do you mean by 'supplier'? ....
In my signature below you will see pictures of my kit. The small red fronted box ontop of my main headphone amp is The Supplier. It is a power supply for the Fubar DAC which is the small grey fronted box to the right of the main amp. The round object to the left is my other headphone amp. There is another headphone amp in the drawer below. I am a headfier!
Monkeyboy3001:
......  I have 4GB memory, I think this will get me started but I can add more if needed. Richard
That is barely enough to get you going. My 80gb ipod is full at 350 odd CDs, not all of which are at lossless bit rates. How many CDs have you got?
__________________
Fumanchu
Fumanchu's picture
I think he is refering to Ram rather than space on a HDD...
I have also used WASAPI with FB2K and also reclock with VMC, IMHO there really isn't much difference in sound quality at 16bit... Sure WASAPI bypasses the OS faff, I would go with Flac if you need the disk space and have a desire for lots of tag options... Otherwise (if windows) go with WAV and have WMP find your album art and meta data, Sorted.
Monkeyboy3001
idc:
.....That is barely enough to get you going. My 80gb ipod is full at 350 odd CDs, not all of which are at lossless bit rates. How many CDs have you got?
I have no clue what I'm on about when it comes to computers, I have 4GB RAM & a 698GB hard drive, it's the hard drive where my music will be stored right??? May slot another hard drive in just for music & pictures. I hear that WAV (lossless) uses about 600MB per CD, meaning I have space on my current hard drive for over 1000 albums.
I have about 600 CD's (I think), long time since I counted em.
Alec
Alec's picture
why did wmp wind you up PJ?
Also, people are aware of the existence of Windows Media Audio Lossless arent they? WAV isnt your only choice as a wmp user.
__________________
Formerly known as al7478...
HC: Panasonic PXP 42 V20; Panasonic DMP BD35; Humax Foxsat-HDR
Music: Optical out from Asus P7H55-M Motherboard into AVI ADM 9.1 speakers.
"Music will provide the light you cannot resist"
idc
idc's picture
Monkeyboy3001:
..... I have 4GB RAM & a 698GB hard drive, it's the hard drive where my music will be stored right??? May slot another hard drive in just for music & pictures. I hear that WAV (lossless) uses about 600MB per CD, meaning I have space on my current hard drive for over 1000 albums. I have about 600 CD's (I think), long time since I counted em.
Yes its the hard drive that is important. I would suggest that even if you don't use itunes in the end that you go there and have a look at the video tutorials to get an idea of how to work media players. http://www.apple.com/itunes/how-to/
Say you do download itunes it sets up a file in My Music on your computer and the music files will be stored in there. Your PC with a 698gb hard drive will take a lot of music. But you also want to get an external hard drive to back up your music onto. Or else if the PC fails or gets stolen etc, you could lose all of your music. One of the features of itunes is that it offers to back up your music for you.
__________________
PJPro
PJPro's picture
Fumanchu:
.....I would go with Flac if you need the disk space and have a desire for lots of tag options... Otherwise (if windows) go with WAV and have WMP find your album art and meta data, Sorted.
Why would anyone want to use .wav? More space, no tagging, no difference in sound quality. Beats me.
__________________
PJPro
PJPro's picture
al7478:
Probably something trivial......it wouldn't take much to make we want to play with something else. But I'm now content that F2K does everything thing I need as well as appeal to my tinkering nature.
__________________
idc
idc's picture
The extra bits to the likes of Foobar (also known as F2K -  Foobar 2000) and Song Bird mean they not for the beginner. I would stick to itunes and Windows Media Player. Both are very straightforward, or as straightforward as you can get.
Note - Foobar is a media player/music file manager that can be downloaded off the internet. Fubar is a DAC made by Firestone Audio. Its easy to see how confusing it can get when you start out.
__________________
Pete10
Pete10's picture
I tried several programs before I decided to stick to MediaMonkey. Reasons? Not sound quality for sure, they are all the same if your system is configured correctly, just personal preferences. MM worked immediately after installing, Foobar required some more knowledge/customizing (I assume you rather avoid that, given the previous posts), WinAmp's interface was not for me, WMP was actually not bad, just didn't like the library implementation. Just personal things, and I am sure that if I had spend more time with some of the other programs they would have worked for me also. You can also switch later: cd's are just stored in folders, and all programs can read the information. So just try a few programs, they are free, and see which one you like best.
If you start ripping do it lossless - you only want to do this once, and programs let you download CD information and add it to the tags. It is easy to convert tracks, and programs like MM let you synchronize with mobile devices and does the conversion on the fly if needed.
__________________
Netgear WNDR3700 share > Asus Netbook  (W7 & MediaMonkey/Foobar) > USB MF V-DAC > Primare A10 > Monitor Audio GR20
Netgear WNDR3700 (DLNA) > Android/XBOX/PanaTV/Humax
Monkeyboy3001
Whats your thoughts on windows media audio lossless v's WAV?
