Synology NAS DS212 Airplay sound quality
Can anyone comment on the sound quality of the Airplay sent to an Airport Express from the Synology NAS compared to iTunes through a Mac? I am sure my iPhone does not sound anywhere as good as iTunes thorugh Airplay.
Also, is the DSAudio app for iOS good? Can I use this as an alternative to a media server like a Squeezebox or do I need to keep the MacBook on?
iTunes in a MacBook Pro vs iPhone, both into an Airport Express connected to a Caiman DAC... it's different... sounds compressed...
If the file format & bitrate is the same, it shouldn't matter whether the song is stored in an iPhone or a MacBook. Can you confirm the file format & the bitrate?
Yes... The exact same file, from the iPhone sounds much lower and a bit compressed. Theres more dynamics and air through iTunes. And a lot louder too...
- Login to post comments
Sound quality of the AirPlay?? It depends on the speakers where it's sent to, to start with. What are you comparing your iPhone with?
My Home Cinema Pioneer KRP 500A, Yamaha RX-V1900, MA Radius R225HD LCR, R90HD rears, AW12 sub, Panasonic BD60, PS3, Boxee Box, Sky HD, Boxee Box, Logitech Harmony One, Logitech PS3 Adapter, Sonos ZP90
