Streaming confusion NP30 + DAC or stream magic 6
6 replies [Last post]
def lugs
def lugs's picture
Hello chaps - I am after some advice on a dedicated music streamer. I currently use my Oppo 93, feeding into a Dacmagic 2 for music listening duty < both streaming and CD. I am happy with the result but not happy with the slow interface and the fact I need to switch TV on to find specific tracks.
I have auditioned the Cambridge NP30 which interface was good but sound quality did not live upto my current solution. I was unable to audition the NP30 feeding into a separate DAC. I thought the NP30 on it's own lacked detail and accuracy placing intruments correctly in the soundstage.
I was wondering if any forum users had tried out this combination and could comment on its sound quality?
I also auditoned the Stream magic 6 - this was a good step up from a NP30 and provided a very pleasing listen but at £700 will take another couple of months saving.
Another option is a squeezebox touch feeding into a DAC - however this would require purchasing a new NAS drive as my current WD MyBook Live will not run Squeezebox server. Though buying a new NAS and a squeezebox would still leave a lot of change in my pocket over the stream magic so it could still be an option.
John Duncan
John Duncan's picture
RE: Streaming confusion NP30 + DAC or stream magic 6
Will answer this tomorrow...
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
nads
nads's picture
and you could sell the DacMagic.
__________________
Not a HiFi Nut. Just has a pile of Nads.
def lugs
def lugs's picture
Thank's John I would appreciate your views.
This would then leave me without a DAC?
Alec
Alec's picture
Online
The DAC in the Touch is pretty well regarded. I haven't heard it though, so don't take this as advice to go one way or another.
__________________
Formerly known as al7478...
HC: Panasonic PXP 42 V20; Panasonic DMP BD35; Humax Foxsat-HDR
Music: Optical out from Asus P7H55-M Motherboard into AVI ADM 9.1 speakers.
"Music will provide the light you cannot resist"
def lugs
def lugs's picture
Thanks Alec I have heard good reports about it but would not buy unless I can have a listen first.
nads
nads's picture
well mine soon got sold after the Touch was bought.
If you need a DAC for other boxes look at one that would also be an improvment for the Squezebox. I have no need for a DAC at all any more.
__________________
