squeezebox touch and duet
4 replies [Last post]
pauladamss
pauladamss's picture
does anyone know if you can use the squeezebox duet controller with the touch instead of using the provided plastic job
armpowered
armpowered's picture
Re: squeezebox touch and duet
Yes,  I replaced the Squeezebox Receiver with a Touch and can control either via the touchscreen, Duet controller or basic IR controller.
pauladamss
cheers i think i will go down that road maybe get the controller s/h on ebay and then a dacmagic using a samsung story for storage and my note pad
simonclayt
simonclayt's picture
I have both Touch and a Duet - the IR  RC is faster with line of sight to the Touch,  but the wi fi Duet controller can switch between any of the Squeezebox devices on your network - I am also running a Receiver and a Classic, and it is simple to switch between them with the duet.
 The Touch is a really neat bit of kit and a bargain at £220 (offer)
nads
nads's picture
or you can use a iTouch or iPhone.
and I dont think the DacMagic is needed with the touch.  Mine is not.
__________________
Not a HiFi Nut. Just has a pile of Nads.
