nas - amp advice for a total newbie.....
2 replies [Last post]
Mrboots2u
Mrboots2u's picture
Hi I am stuck and am need some advice from your good selves please.
I have a macbook and an ipad which me and my partner share. Am looking for a NAS ( been told synology are good ) to store all our combined music on .
I would then like an amp ( to connect to my Mission x 3 speakers ) , which i can connect to the nas and play the music off. one with interent radio would be good too.
All the music is on itunes so would need an itunes server i presume and would operate form the macbook/ipad.
Would somehting like an Onkyo amp work ( 8050 ) or am I better getting something else.
Am really open to suggestions as my knowledge level is terribly low . Budget wise say up to £500 for the amp. For the Nas probbaly around £250 ( for 1tb storage )
Cheers M
celsius
celsius's picture
RE: nas - amp advice for a total newbie.....
hi
the onkyo tx 8050 would be ideal as for the nas bear in mind that synology and qnap don't come with hard drives installed.i use a buffalo which you can get a 1tb for about £100.
__________________
naim unitiqute,b&w cm1,i5 silent pc, boxee box,synology ds1812+ with 4xwd red 3tb and 2xwd green 2tb
panasonic 32lxd60
grado sr125,klipsch image x10,ipod classic 120gb
Mrboots2u
Mrboots2u's picture
Thanks I am going to give the onkyo a go with a synology nas
