little bit of advice regarding rips please
19 replies [Last post]
GSB
GSB's picture
Hi folks......well,have riped all my cd's in flac,then made apple lossless copies.
Thing is,in the flac folders the music has been duplicated..showing copies as flac but the lossless is fine?!
Anyone suggest a quick fix to this please?
many thanks
Graham
__________________
PanasonicTX-P46GT30B..Yamaha RX-A1010...Music Fidelity M3i...OPPO105EU...KEFR100/R200C/3001SE/HTB2SE...SkyHD2TB...QED Copper Speaker Cable /HDMI/Analogue...PS3...IPAD2
scene
scene's picture
RE: little bit of advice regarding rips please
Do you just want to keep the apple lossless copies, or separate the flac ones out somewhere else?
__________________
Hi Fi: Arcam A85, DV88 (CD only), Project Debut II, AE Compact-1. AV: Arcam AVR250, DV79, Sony BDP-S760, Monitor Audio Silver 8i, RS-LCR, RXFX, Sonos ZP90, Pioneer KRP500A. 2nd AV: Pioneer SX-SWR2, Dell Zino HD, KEF KHT2005.2 eggs, Sonos ZP90. That Cable HDMI, Chord Crimsons and Sonos ZPS5s everywhere & a spare Yamaha RXV-667!
GSB
GSB's picture
I want to keep lossless and flac files,just can't understand why the flac have doubled up?
Flac are in separate folders to the lossless by the way.used dbpoweramo.  to convert flac to lossless...seems its kept the original files and duplicated them!
__________________
scene
scene's picture
Ok, so when you look, are the duplicate flac files in the same directory as the apple lossless, or do you have two sets of flac files in the same folder?
__________________
GSB
GSB's picture
two sets of flac in the same folder,but directory?i have flac in my music,lossless in public music(don't know how else to seperate)
sorry for my ignorance scene
__________________
scene
scene's picture
Easiest thing is to use find to find ONLY the duplicate copies, and then delete. Are the dupes all called something like "copy of ..." or "track 001 (1).flac"?
If so, use windows find to find all files that match the naming match, starting I the top level music folder
__________________
GSB
GSB's picture
They are exactly the same.....not looking forward to going thru 80odd albums  help, I`m sinking
They play ok,just wanted to tidy folders,but I think I'll live with it for a while...
__________________
The_Lhc
The_Lhc's picture
If they're in the same folder they can't be identical, you can't have two files with the same name in the same folder.
__________________
No signature worth mentioning...
scene
scene's picture
Seriously, if they're in the same folder, the actual files cannot be called the same thing. Try viewing one of the folders in windows explorer, and using the option to show extensions, in case the file names are the same, but the extensions are different.
__________________
GSB
GSB's picture
in the album folder,some but not all songs are dupe...the strange thing is that the play lenghs are different.there is not mention of one being a duplicate either however one version does have a star rating.
I dont know what i have done,and i believe what you both say is true,wonder how they got there.... also the track playlisting is all wrong on all albums doh! ohhh sure rolling on the floor laughing
__________________
The_Lhc
The_Lhc's picture
What did I say to you last week? I said stick to CDs, this isn't going to end well.
__________________
Lee H
Lee H's picture
Using your media player of choice (Mediamonkey for example) load up the flac library, sort by track name and get clicking. Assuming you're running windows, holding down Ctrl will let you click multiple tracks. Highlight all the duplicates (easy to spot now they're in track order) and then delete.
Mediamonkey can also help you organise/sort your track listings etc. I find it invaluable as a management tool.
__________________
Formerly Still known as Lee H
GSB
GSB's picture
Calm down dear,they all play and i have listened to albums previously unheard for years...all wirelessly,and all controled of my new 1pad2 party time!
__________________
GSB
GSB's picture
Thanks for the advice Lee....i have mediamonkey so i will have a play Cool
__________________
GSB
GSB's picture
Right thas sorted,there was an itunes folder lurking on my drive that was the source of confusion.
Every thing streams nice,but one more question,if anybody's still talking to me?!!
On most album rips the playback is good,no issues(apart from wanting to add some stereo speakers)but for my floyd albums and such like when tracks kind of merge,there is a break...at the merging point.
Question is this,if i re-rip...with what i believe is called gapless would this sort this lil problem?
Oh...one more thing shifty ........got myself an ipad to control the avr.....it shows the UPnP but not mediamonkey,whereas on the tv display it shows both,any advice greatfully recieved puzzled
cheers
Graham
__________________
GSB
GSB's picture
Been doing abit of typing away and may seem that streaming via my AVR is the problem.I have re-riped an album useing dbpoweramp's gapless dsp,and althgough it is much better,there is still a very slight'hesitation'.
Is DNLA the problem?
__________________
